  Raising glass with a bad motor
Raising glass with a bad motor by 85_Fiero_2M4
Started on: 04-07-2018 09:18 PM
Replies: 4 (201 views)
Last post by: theogre on 04-09-2018 11:20 AM
85_Fiero_2M4
Report this Post04-07-2018 09:18 PM Click Here to See the Profile for 85_Fiero_2M4Send a Private Message to 85_Fiero_2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey everyone,
I recently picked up a 86 GT with power windows, that needs some TLC. It's been in my garage for a few months now. But I want to take it outside and park it (covered up) for a few days. The passenger side window is down right now, and I'm pretty sure the motor is bad. It makes a sound when I press the switch, but no movement and I can't the switch and lift the glass.
I know I'll have to replace the motor, but is there any quick fix to lift the glass? Maybe a certain rivet to drill out. I'm sure I'll have to keep the glass in position with some duct tape. But I just need a temporary solution for a few days.
Any ideas?
Andrew
dratts
Total ratings: 118
Report this Post04-08-2018 10:43 AM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try pulling the glass up while pushing the button. It works on mine.
hnthomps
Total ratings: 50
Report this Post04-08-2018 07:59 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can second this approach. When I was having issues with my window, I used both hands (one on either side of the window) and had either my wife or some other helper push the button. I also used a similar approach on a Towncar with bad motors in the rear doors.
Nelson
Spoon
Total ratings: 61
Report this Post04-08-2018 08:23 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
If none of the above work you could have a dirty or worn out switch and not passing enough current to lift the window. This happened to my son's Jeep so I pulled door panel and separated the pigtail on the window motor and applied direct battery power (I might of used a charger) to the pigtail. Up the window went without help. Reverse the connection and it will go the other direction.
Spoon
Report this Post04-09-2018 11:20 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup try this and/or pull up or wiggle front/back direction.
Door connector is behind the carpet for A pillar. 2 big wires.
If those don't work then have to dig into the door to find the problem(s).
