  Spring rate bouncy
Spring rate bouncy by SP1200
Started on: 03-11-2018 01:28 AM
Replies: 16 (577 views)
Last post by: fieroguru on 03-15-2018 02:09 PM
SP1200
Report this Post03-11-2018 01:28 AM Click Here to See the Profile for SP1200Send a Private Message to SP1200Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I have a question. What makes a spring more bouncy? A soft or firmer spring?
I'm wondering because I have a bounce. it feels like in the front of the car. Not sure if it's the front or rear springs...or perhaps a transfer of the weight from fronts to rears is causing the bounce. My setup: 1986 GT Fastback
197 lbs Moog #6556 (FRONT)
275 lbs AFCO Coilover Springs #22275CR (REAR)
Just wondering if I were to get stiffer rear springs if this would improve the ride?
Total ratings: 466
Report this Post03-11-2018 02:27 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
What makes you believe your springs are the source of this "bounce"? I'd suspect blown shocks and/or struts first.
Total ratings: 260
Report this Post03-11-2018 10:24 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Give us a full run down of the suspension on your car. Stock or lowered, poly or rubber bushing, which shocks/struts, springs, wheels, tires, etc...
SP1200
Report this Post03-11-2018 01:11 PM Click Here to See the Profile for SP1200Send a Private Message to SP1200Edit/Delete MessageReply w/QuoteDirect Link to This Post
Right. Right. Sorry. my bad.
Because I replaced the Front shocks (Monroe Sensa-Trac) when I installed the new front Mogg springs to raise the car for my new 18" rims. That's when I noticed the bounce.
Previously I was running the same rear setup (Custom AFCO coilovers on KYB's) but with the lower OEM ARC 88 12" Front springs on my 1986. With the ARC's at first I had KYB shocks but they seemed to stiff, hitting California pot holes and what not, so I swapped them out for softer Monroes. Which felt more comfortable and seem to handle the potholes better at that time.
So I'm wondering if I have a bad spring combo, (197lbs Monroe's to 275lbs KYB's) or if its shocks and struts.
One note: I personally felt that one of the monroe shocks wasn't quite as "good" as the other one when I ordered the pair. I could hear gas squirting inside when I would compression test the unit. I was told years ago the hand test was not accurate anyway and to ignore it. Also it seemed the "NEW" shocks were not better than the old parts. But they were new so I put them in.
Total ratings: 260
Report this Post03-12-2018 08:08 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would go corner to corner and jounce the car to see how many ups/downs it take to stop.
Typically a bouncy ride is from the springs having too high of a spring rate for the shocks/struts to properly dampen, but your spring rates are quite mild. Another cause is if you are riding on the bump stops (effectively a high spring rate), but your car should be close to stock height. Another cause is bad shocks/struts, even if new, they have likely been sitting on the shelf a long time and could still be bad.
SP1200
Report this Post03-12-2018 02:15 PM Click Here to See the Profile for SP1200Send a Private Message to SP1200Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well I don't have hardly any up/downs from the bump test.
The front of the car (when hopping my body on it) seems stiff. And the rear has some down, but not any up.
I'm wondering it I can add stiffer rear springs. I'm thinking the stiff bouncing is the weight traveling from a firm front to a less firm rear end.
The Front 197 to Rear 275 isn't much difference considering the weight of the stock 2.8
What about upgrading the rears to 300 or 350 lbs springs?
[This message has been edited by SP1200 (edited 03-12-2018).]
Total ratings: 260
Report this Post03-12-2018 11:19 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Something isn't right in the front.
The front springs have a motion ratio of about .5 (they are placed about 1/2 the way between the lower a-arm bushing and ball joint). With a 200 lb/in spring, the effective spring rate at the wheel is about 50 lb/in. So if you sit on a front fender, the suspension should go down. If it doesn't, something is binding, you are sitting on the bump stops, or the spring rate is much, much higher than 200 lb/in.
In the rear the motion ratio is about .97, so your 275 spring rate, becomes about 258 lbs/in effective spring rate at the rear wheel.
SP1200
Report this Post03-12-2018 11:48 PM Click Here to See the Profile for SP1200Send a Private Message to SP1200Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry. I checked again. Nothing is binding. I used a tape measure and jumped on the front.
I got it to drop anywhere from half inch to almost in inch.
The rear I could not measure as Im alone, but it drops quite a bit.
Total ratings: 260
Report this Post03-13-2018 12:26 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the corner with a 50 lb/in spring rate at the wheel moves the same or less than the corner with the 250 lb/in spring rate at the wheel... something is wrong.
SP1200
Report this Post03-13-2018 12:50 AM Click Here to See the Profile for SP1200Send a Private Message to SP1200Edit/Delete MessageReply w/QuoteDirect Link to This Post
All sides seem to move about the same. I'll get a buddy over to measure with a tape when I jump on. I'm 220lbs is that enough?
Does the height adjustment of the castle nut on the coil-over sleeves make any difference?
Does the aluminium sleeve flex at all?
Total ratings: 466
Report this Post03-13-2018 01:52 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think someone of your weight should have little trouble getting the front suspension to travel more than "half inch to almost in inch".
Turn your front wheels off to either direction and have a look at your front bump stops. There should be plenty of room between them and the lower control arms. Pictured below is an old photo of my '84 with cut springs before I shortened the metal cones of the front bump stops. Notice how the rubber bumper of the bump stop is actually sitting on the pad of the lower control arm. Your suspension with the new replacement stock height springs should not have this issue... but double-check and let us know.
SP1200
Report this Post03-13-2018 08:39 AM Click Here to See the Profile for SP1200Send a Private Message to SP1200Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump stops were trimmed years ago. There is plenty of clearance.
Blacktree
Total ratings: 350
Report this Post03-14-2018 12:56 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
This may seem counter-intuitive, but the front suspension needs firmer springs than the rear. Due to the suspension design, the front springs have much less leverage than the rear springs. As a general rule of thumb, the front spring rate should be about 1.5x the rear spring rate. You can see this in the stock spring rates, where the front is around 200-220 lb/in and the rear is around 140-150 lb/in.
Because your rear suspension is significantly stiffer, the front is going to feel like it's bouncing around. That's because the front end moves around more, while the rear end is firmly planted. You can correct that by either firming up the front suspension, or softening up the rear.
Oh, and here's a little story: I experienced a similar phenomenon during my latest suspension upgrade. In a previous upgrade (back in 2004), I had installed KYB dampers and Eibach springs all around, with urethane bushings. My new suspension was installed in 2 stages. The first stage was the rear suspension: 350 lb/in coilover springs, Koni struts, '88 rear cradle, and rod-end suspension links. So for a short while, the rear suspension was significantly firmer than the front. It made the front end feel bouncy. The sensation was almost as if the front shocks were bad. When I installed the new front suspension (Koni shocks, 500 lb/in springs, and tubular control arms with rod-ends), the bounciness in the front end went away.
[This message has been edited by Blacktree (edited 03-14-2018).]
SP1200
Report this Post03-14-2018 07:55 PM Click Here to See the Profile for SP1200Send a Private Message to SP1200Edit/Delete MessageReply w/QuoteDirect Link to This Post
^ Wow that really interesting! humm. Maybe I should try some softer springs in the rear and see how it goes.
SP1200
Report this Post03-14-2018 11:26 PM Click Here to See the Profile for SP1200Send a Private Message to SP1200Edit/Delete MessageReply w/QuoteDirect Link to This Post
SP1200
Member since May 2016
So I'm thinking to remove the spare tire and putting some sandbags up front to test this issue.
Only temporary, but at least I could see if the rapid bouncing sensation will decrease.
mender
Report this Post03-15-2018 10:43 AM Click Here to See the Profile for menderSend a Private Message to menderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Motion ratio at front is 0.69 by my measurements, making the wheel rate about 50% of the spring rate or about 100 lbs/in with a 200 lb/in spring, not 50.
[This message has been edited by mender (edited 03-15-2018).]
Total ratings: 260
Report this Post03-15-2018 02:09 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't have the info for the 84-87, so I was using the information for the 88. Thanks for providing the 84-87 info!
