  Ignition coil bracket
Ignition coil bracket by 4evrnyt
Started on: 02-23-2018 10:10 PM
Replies: 3 (235 views)
Last post by: 4evrnyt on 02-24-2018 02:19 PM
4evrnyt
Report this Post02-23-2018 10:10 PM Click Here to See the Profile for 4evrnytSend a Private Message to 4evrnytEdit/Delete MessageReply w/QuoteDirect Link to This Post
How do people generally remove the stock ignition coil bracket from the old coil? I purchased a new Delphi coil to freshen up the engine bay and it came with some flimsy brackets that I can't make any sense of.
Thanks.
Total ratings: 154
Report this Post02-23-2018 11:29 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Grind or chisel the heads off the rivets of the old bracket, then replace them with screws, lock washers and nuts or locking nuts.
Report this Post02-24-2018 04:49 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
No mater how you change the brackets...
HEI coils should have iron "core" grounding to the block. Often will have problems when you don't have this.
4evrnyt
Report this Post02-24-2018 02:19 PM Click Here to See the Profile for 4evrnytSend a Private Message to 4evrnytEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the replies and suggestions. Cut it off with the Dremel.
