Adding volts often won't help them and can make worse problems. "12v systems" should have 14-15v when the alternator is on and "12v" DC is already hard on relays and switches. Problems w/ Fiero PW switches are a good example. 10-15 years back was a push for 42v systems in cars but stopped because is multiply harder to make contacts to handle higher DC volts. Several are trying again w/ 48v but don't hold your breath for being common soon. (Note that most switches etc you buy have AC amp ratings on them but if you push same amps on DC then you will fry them and likely very quickly.)
Even If Gen1 motors get full power, They are slow because of motor gearing vs Gen2 at same volts.
Cardone New Gen2 motors open/close the HL in about 2/3 of 1 second. OE Gen2 ones are around 1 sec. Working Gen1 are notably slower but passes FMVSS 108 3 sec limit for hidden HL.
But...If motor's have ground and/or power problems, they will be slower then that and Gen1 can "fail" that limit. Worse Power/ground often means motors run at low volts and try to pull more amps and often can't w/o burning relays and switches.
See my Cave,
Electric Motors | quote | Originally posted by fierofool: I used a battery charger to test a motor and at 12 amps, it popped a small spring metal piece on the points, rendering the limiter switch useless. |
If you mean blows the motor circuit breaker? No surprise. Most 12 amp charger will putout more then 12 amps to a inductive load until something shuts off or fries. Most charges if they even have a fuse/breaker is on 120v AC side so when the charger dies the Building won't dump 15-20a @ 120v AC. Building Breakers/Fuses won't blow when a died thing have some resistance but same died thing often will melt or catch fire w/o smaller fuse and/or thermal cutout built into them.
