All cars not just Fiero should popup/open the HL motors w/ engine running or not.
Even many old Vacuum "motors" operate 1 to ~3 times when reserve tank is "full" and check valves work. After then I think they stay open until have engine vacuum again.
See my Cave,
Gen 2 HL MotorTurn motors ~1 turn after shutdown then turn on/off HL switch. If motors work then the motor(s) have problems.
Because sounds like motor(s) "flake" working for whatever testing you run but Module still sees motor binding/jamming and shut them off as made to do.
Module w/o motors will turn on until timer runs out in ~5 sec then shuts off.
Note: Everything in front ground near both HL lifts. If crappy there then very likely you will have problems w/ HL motors, Dim lights, Radiator fan, and maybe other things. Clean/fix wire ends and body then coat everything w/ silicon or brake grease to "seal" out water etc.
Iffy Gen2 motors are iffy then use Cardone w/ a warranty.
DIY methods may work for a few days to years depending how much you use your headlights and exact method of "fixing"/"rebuilding."
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 01-15-2018).]
