  2.8's are non-interference engines, right?
2.8's are non-interference engines, right? by Will
Started on: 01-11-2018 08:30 PM
Replies: 5 (483 views)
Last post by: pmbrunelle on 01-12-2018 11:28 PM
Total ratings: 237
Report this Post01-11-2018 08:30 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 198k mile Formula appears to have broken its timing chain.
It's not my favorite engine, and not what I wanted to do this weekend, but if I can just "toss" a timing set into it, that would be better than moving up plans for a 3900/F23 swap.
pmbrunelle
Total ratings: 63
Report this Post01-11-2018 08:51 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think so, but that's a guess.
Tomorrow evening (but not today) I'll have access to a pair of 2.8 Fiero heads, so I'll be able to measure the distance from the machined head gasket surface to the valves.
Standard head gasket is 0.040" thick, and the piston is 0.026" (says 60degreev6.com) in the hole.
The heads I have are old, so they will have some valve seat recession, but they have less miles than yours do.
You can probably find valve lift specs with a search of the forum.
Report this Post01-11-2018 09:38 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
If they are an interference engine, we would have heard of it by now....
Blacktree
Total ratings: 350
Report this Post01-11-2018 11:02 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
They are not interference engines.
Spadesluck
Report this Post01-11-2018 11:56 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just line up the timing marks when putting a new chain on and call it a day plus all the gaskets that need to be replaced as well. Now getting to all that is another story.
pmbrunelle
Total ratings: 63
Report this Post01-12-2018 11:28 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Distance, closed valve to machined gasket face on head.
Approx. 155k miles.
Intake: 0.360"
Exhaust: 0.330"
Measurement confidence (consider that I held the slide caliper feedhand, and there was still some carbon on the head):
Most probably the above measurements are within +/- 0.015" of the truth.
