  3800 SC Fuel Pressure Regulator
3800 SC Fuel Pressure Regulator by RotrexFiero
Started on: 08-05-2017 11:17 PM
Replies: 3 (499 views)
Last post by: fieroguru on 08-06-2017 10:43 AM
RotrexFiero
Report this Post08-05-2017 11:17 PM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Swapping out the Supercharger on my 3800 SC.
The fuel pressure regulator has a vacuum line.
It was attached directly to the old SC, but my new SC has no provision to attach it there.
Can I attach this line to a vacuum/pressure on the lower intake manifold?
This is the same place my boost gauge is connected, so the fuel pressure regulator would see vacuum and pressure. Is that appropriate to its function?
Thanks
Report this Post08-06-2017 01:02 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The FPR and MAP should be attached to port on LIM under snout.
RotrexFiero
Report this Post08-06-2017 08:29 AM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
So the FPR sees vacuum and boost?
Report this Post08-06-2017 10:43 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. It helps equalize fuel flow through the injectors across all load levels.
