I've always had trouble with my right headlight motor on my 88... Slow, wouldn't open when under battery power alone (car had to be running for the added voltage for more torque) grinding, flat out wouldn't work at times, and most frustratingly, would only go up halfway on rainy days unless I opened the front hood to take load off the motor... I took the sucker out and first off noticed it was a reman unit from an unknown source. I checked play in the "shaft" by pushing up and down on the little cap thing you can spin by hand to open the lights and found a bunch of play, I'd say a good 1/8 inch up and down movement. (The driver side has almost no play.) Upon disassembly the grease on the inside was all dried up. As expected, the white shear pins are still all in one piece, as well as the gear, since the headlight motor still "worked" I took the motor apart further to investigate and didn't notice anything wrong until I watched a video on rebuilding these things.
I watch the guy on YouTube disassembling the thing, and see him pull out a ball bearing that sits under that "worm gear" output shaft of the motor that spins the plastic gear with the shear pins! That bearing is missing from mine! That explains all that play I seem to have there! I'd also assume that this is my problem with the motor being so temperamental at times, humidity and temperature, added play and grinding noises intermittently...
Geez that was a long story.
At any rate, before I buy a reman unit, I wanted to ask anyone on here if they know where I would be able to find a correct size replacement ball bearing. If not, does anyone have a unit all disassembled with the ability to measure it and tell me what the size is to find a replacement?
I'm not gonna go crazy though, these things are fairly common, if I can't get that ball bearing I'm gonna get a reman unit from Cardone and call it a day.
Any words of wisdom would be awesome guys! Thanks!
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
