|  | | quote |  | Originally posted by Jacbnim:
 I recall putting E3 plugs in last fall, and do recall this plug being slightly loose, which it is now but only wiggles about a centimeter.
Loose in the socket or loose where it screws into the head?
 I guess a better question is, without dropping the cradle... Again... Is there a way to clean out the housing the plug sits in?
You sure as heck don't need to be dropping the cradle to remove a spark plug, especially one that was installed less than a year ago.
Use a small mirror and a light to see what the issue is. If it's debris, blow it out with compressed air, or use a shop vac and suck it out. Access can be made easier (if required) by removing the decklid. (Remove the four bolts holding the hinges to the decklid... do
not remove the bolts holding the hinges to the body. Protect the rear window in case the limiting cables are corroded and let go.)
[This message has been edited by Patrick (edited 07-08-2017).]
