  Is Blue Devil Oil Stop Leak safe to use?
Is Blue Devil Oil Stop Leak safe to use? by dshallock
Started on: 06-26-2017 02:53 PM
Replies: 5 (810 views)
Last post by: dshallock on 06-28-2017 09:20 AM
dshallock
Report this Post06-26-2017 02:53 PM Click Here to See the Profile for dshallockSend a Private Message to dshallockEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have some oil drops under my 1986 Fiero GT. I think it is the oil pan gasket. Is it safe to use Blue Devil Oil Stop Leak to try and get it to stop or am I risking causing more damage then it's worth?
Tony Kania
Total ratings: 305
Report this Post06-26-2017 03:17 PM Click Here to See the Profile for Tony KaniaSend a Private Message to Tony KaniaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check your pan bolts first.
wgpierce
Report this Post06-26-2017 06:49 PM Click Here to See the Profile for wgpierceSend a Private Message to wgpierceEdit/Delete MessageReply w/QuoteDirect Link to This Post
And check around your distributor and make sure it's not leaking at the Oring. I would NEVER EVER use stop leak anything unless it was a dire emergency. And even then it probably wouldn't be wise
[This message has been edited by wgpierce (edited 06-26-2017).]
Report this Post06-27-2017 09:35 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would only use Oil Stop Leak in an engine that is on its last legs. I've used it once and it worked but it was on a car that was soon disposed of. You could say it was safe as the engine ran for a few thousands of miles afterwards but putting something in an engine that is essentially a compound to make the gaskets swell is IMO not a good idea.
Report this Post06-27-2017 12:35 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Try running "high ,mileage" oil, it has a small amount of seal conditioners, not as harsh as the oil stop leak products.
Castrol semi synthetic has worked for me on cars before.
But also yeah. Valvecover, oil pan bolts and distributor base o ring can leak.
dshallock
Report this Post06-28-2017 09:20 AM Click Here to See the Profile for dshallockSend a Private Message to dshallockEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you everyone! I ended up taking it to a shop. They put it on the lift so I could check it out. I found out the oil pan was dented on the side most likely compromising the seal. Just to be safe I am going to have them replace the seal, pan and valve stems. The car only has 52k miles and hope to keep it on the road for some time to come.
While on the lift I noticed the shocks were leaking and my ball joint needs replace but that will be a battle for another day!
