  Alternator bolts
Alternator bolts by CrazyDragn
Started on: 06-13-2017 11:20 AM
Replies: 3 (493 views)
Last post by: fierofool on 06-13-2017 08:25 PM
CrazyDragn
Report this Post06-13-2017 11:20 AM Click Here to See the Profile for CrazyDragnSend a Private Message to CrazyDragnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can anyone tell me what size bolts I need to use with FieroRog's alternator bracket, you know, the bolts to the factory alternator not the ones that come with his kit.....
I really need to get those, just do not know the size......
Notchie to Fast Back Conversion
After Market Steering Wheel Conversion
Report this Post06-13-2017 12:34 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Top Pivot Bolt---Flange head bolt M10 x 1.5 x 90 x 9.8 POR
Adjuster Bolt---Con tooth M8 x 1 25 x 32 9.8 PH (Con Tooth = full length threads)
Shield Bolt---M8 x 1.24 x 16 Full 9.8 PS
Shield Bolt Washer---Met. Reg. Helical Lk (M8)
I've had difficulty getting some metric fasteners at the parts houses, but between Fastenal and Tractor Supply, I always come back with what I need.
[This message has been edited by fierofool (edited 06-13-2017).]
CrazyDragn
Report this Post06-13-2017 05:36 PM Click Here to See the Profile for CrazyDragnSend a Private Message to CrazyDragnEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need the size of the two bolts that go on the bottom.
you know, there is one that is long and the other is short.
Report this Post06-13-2017 08:25 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The lowermost bolt that goes through the stock bracket is listed as HFH (m8 x 1.25 x 75 9.8POR)
The next low bolt is only listed as BOLT, Eng. Mt Brkt with WASHER (Eng Mt Brkt to Cyl Blk) No specs given
These are the ones that go into the block, not the cylinder head.
Pages 60 and 62 of the Fiero Parts Book.
