  88 vs 87 clutch fork difference
88 vs 87 clutch fork difference by yamahasrx700
Started on: 05-31-2017 06:55 PM
Replies: 8 (183 views)
Last post by: yamahasrx700 on 06-01-2017 12:54 PM
yamahasrx700
Report this Post05-31-2017 06:55 PM Click Here to See the Profile for yamahasrx700Send a Private Message to yamahasrx700Edit/Delete MessageReply w/QuoteDirect Link to This Post
does any one know what the actual difference between the two clutch throw out bearing forks are? Do they interchange? If not why?
Total ratings: 463
Report this Post05-31-2017 07:09 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might want to mention whether you're referring to an Isuzu or Getrag tranny.
yamahasrx700
Report this Post05-31-2017 07:57 PM Click Here to See the Profile for yamahasrx700Send a Private Message to yamahasrx700Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good point its a Getrag
Total ratings: 463
Report this Post05-31-2017 08:10 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe the 5-spd Getrags used in the '87 and '88 Fieros are the same, therefore the clutch fork should be as well... but I don't know for sure. What leads you to suspect they are different?
[This message has been edited by Patrick (edited 05-31-2017).]
yamahasrx700
Report this Post05-31-2017 08:34 PM Click Here to See the Profile for yamahasrx700Send a Private Message to yamahasrx700Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero store lists 2 for the 88 V6. One is the same as the 87 the other says "Machined between forks". Rock Auto lists one for an 87 but not for an 88
yamahasrx700
Report this Post06-01-2017 11:46 AM Click Here to See the Profile for yamahasrx700Send a Private Message to yamahasrx700Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone???
Rodney
Total ratings: 267
Report this Post06-01-2017 12:21 PM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The ends inside the trans case differ. The non machined one is longer and a larger diameter. Goes into a brass bushing. The machined is smaller and goes into a needle bearing. If you have a non machined one it could probably be machined to match the one with the small end.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
Report this Post06-01-2017 12:21 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Apparently GM changed the bearings half way through the 88 model run. I don't know of anyone who has purchased the $400 replacement fork that the Fiero Store is trying to sell. The early 88 fork with bushings should be the same as 85-87.
https://www.fierostore.com/.../Detail.aspx?s=54030 1988&d=85&p=1
yamahasrx700
Report this Post06-01-2017 12:54 PM Click Here to See the Profile for yamahasrx700Send a Private Message to yamahasrx700Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you. Now I know I ordered the correct one
