  Steering rack ratios?
Steering rack ratios? by Boot
Started on: 05-29-2017 01:33 PM
Replies: 11 (873 views)
Last post by: pmbrunelle on 06-01-2017 08:53 PM
Boot
Report this Post05-29-2017 01:33 PM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi all,
Ive been setting up my car for autocross, and Im wondering if all Fieros had the same steering ratio. I drove my friend's Miata the other day, and its SO much nicer for going through twisties because you dont have to turn the wheel uncomfortably far on every turn.
Anyways. My car is an '87 SE V6. Ive got an 85GT and an 84 2M4 for parts cars, would either of those have a lower ratio? If not, is there another GM junkyard car I could use for a swap?
Thanks!
Originally posted by Frank2:
here's the goal: Build a mid engine car 1/2 as good as a Lotus Elise at 1/10 the cost.
I have no idea what Im doing, but Im doing it.
IG: @giveintogravity
Total ratings: 154
Report this Post05-29-2017 01:55 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
There were at least 2 rack ratios for the 84-87. I don't know about the 88's. I replaced the rack in my first 85GT back in the mid 90's and I remember I had a choice between two ratios. I think they were 3:1 and 3.5:1
viperine
Report this Post05-29-2017 02:51 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might consider a smaller steering wheel for the "Twisties". Extra effort to move the wheel, but travel makes it feel much sportier. I hated how the grant wheel looked in my 87GT, but it sure was a cool feeling on turns.
Total ratings: 207
Report this Post05-29-2017 03:07 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The rack on the 85 GT is faster than the SE rack.
88's all had same ratio.
Total ratings: 154
Report this Post05-29-2017 09:57 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I listed the ratios wrongly. (I think they were 3:1 and 3.5:1)
I believe it was 3 turns lock to lock and 3.5 turns lock to lock. Not sure of the exact numbers, but you get the idea. Three turns lock to lock would be the faster ratio.
Joe, did following years have different ratios, depending upon body trim?
pmbrunelle
Total ratings: 63
Report this Post05-29-2017 11:10 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you do this, keep in mind that a smaller steering wheel may partially block your view of the gauges.
Total ratings: 207
Report this Post05-30-2017 12:16 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pre-88 GTs (and maybe Indy) had the faster rack, all other trims we're the slow rack.
All 88's were the same ratio, which was between the two ratios used previously.
I put GT rack in my 86 SE, made a huge difference in steering response!
Boot
Report this Post05-30-2017 12:37 AM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Perfect, that makes my recent acquisition of the 85 GT even more convenient. Thanks
Now if only the clutch wasnt toasted and the brakes worked
Report this Post05-30-2017 03:17 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Careful: Some states limit smaller SW sizes. (Was common to see 8" to 10" SW decades ago.) When you wreck small wheel becomes a target for lawyers etc.
I had a smaller wheel (I think was 12") w/o PS and while "fun" to drive sometimes... was a big pain in the ass to park and easier to lose control. Big bumps can easily rip the wheel out of you hand. Worse if you put fingers in spoke holes etc then a wheel hitting a hole the SW can break them and worse.
Fiero steering damper can reduce the problems but many remove. (Good ones won't notice them to drive but RR tracks etc are a lot easier on you.)
3 turn rack is harder to park etc too vs 3.5 rack.
sardonyx247
Total ratings: 219
Report this Post06-01-2017 01:36 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
GTs had the 3.0,
It was either the notchbacks or the 4 cyl engines that got the 3.5 turn lock-to-lock (I'm not sure what a notchback V6 has)
88s all have 3.25.
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
Now on my 11th Fiero
Boot
Report this Post06-01-2017 01:54 PM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think I remember reading somewhere that a guy swapped in the 2.0 ratio rack from a Vette, and removed the power steering O rings so it felt like a norma manual rack. Any thoughts on that? Itd be great for the track, but it would suck in traffic.
pmbrunelle
Total ratings: 63
Report this Post06-01-2017 08:53 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have good upper-body strength?
