  Generation 2 headlights in an 85 fiero not working right
Generation 2 headlights in an 85 fiero not working right by Mahpes
Started on: 05-20-2017 02:24 AM
Replies: 14 (469 views)
Last post by: theogre on 05-24-2017 10:46 AM
Mahpes
Report this Post05-20-2017 02:24 AM Click Here to See the Profile for MahpesSend a Private Message to MahpesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bought an 85 fiero 2m6 se and it has the generation 2 headlights in it. They shine but only one will come up and neither of them go down. The headlight motor on the drivers side gets really hot while the one on the passenger side stays cool. Both can be manually twisted up and down so I know the gears aren't stripped. Does anyone know how to start trying to fix this?
Rodney
Total ratings: 267
Report this Post05-20-2017 03:27 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://rodneydickman.com/ca...h=32&products_id=420
Common problem for many many years on the 84-86 Fiero.
Working on my kits I can say you can try an additional ground or two. On both of the relays on the headlight buckets there is a black wire in the harnesses. Tap into those black wires, ground them to create some new grounds. That might help.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
Rodney
Total ratings: 267
Report this Post05-20-2017 03:29 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney
Member since Feb 2000
Guess I missed it has Gen 2 headlights. Sounds like a low voltage problem.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Easy8
Report this Post05-20-2017 07:02 AM Click Here to See the Profile for Easy8Send a Private Message to Easy8Edit/Delete MessageReply w/QuoteDirect Link to This Post
My money is on the headlight control module. Normally mounted in the left front fender well. No idea where it was put in yours. The Orge has a pretty good write up on trouble shooting this system on his page. Then comes the issue of fixing the module if it bad. They are hard to find, and if you get a new one let me know before you toss the old one. Thanks
Rodney
Total ratings: 267
Report this Post05-20-2017 07:05 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
How many wires come out of each headlight motor? If they are Gen 2 they will have 2 wires.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
carguy8t8
Report this Post05-20-2017 09:05 AM Click Here to See the Profile for carguy8t8Send a Private Message to carguy8t8Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you bought the car this way the first thing to figure out is if the car has had the complete gen 2 system installed or if it is just a hack job where gen 2 motors were wired into the gen 1 system. If one of the motors is hot it is because it has constant power going to it and is burning up. You should unplug it immediately.
Mahpes
Report this Post05-20-2017 12:07 PM Click Here to See the Profile for MahpesSend a Private Message to MahpesEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been looking at it, it's a Gen 1 system with a Gen 2 motor in it. The motor has 2 wires coming out of it
Chris Eddy
Report this Post05-20-2017 09:14 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ya, the gen 1 system applied continuous power to the motor assembly, and the end stop switches were the only thing that disabled current flow.
The gen 2 system has no end switches, and relies on the detection of high current (at the end of a stroke) to remove power from the motors at the control module.
So gen 2 motors in a gen 1 system is an ouch.. current would be continuously applied.
Can you post some pictures of the control system up?
Mahpes
Report this Post05-20-2017 11:43 PM Click Here to See the Profile for MahpesSend a Private Message to MahpesEdit/Delete MessageReply w/QuoteDirect Link to This Post
Went out and got some pics of the control system but not sure how to upload them on mobile or if I even can. The drivers side headlight is coming up just fine now, the motor of it still gets hot and the other doesn't come up but they both still shine. Neither go down. Also looked around for the module and it's not in the fender spot and I couldn't locate it, but I also didn't remove the headlights or anything so that's probably why I couldn't find it. Thanks all for replies and help
Report this Post05-21-2017 07:33 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the motor is getting hot I would suggest you raise the headlights then disconnect them until you get it sorted out to prevent the possibility of a fire. The lights will still shine because they are on a different circuit.
Look fur Bruce's Headlight relay thread in this section. Gall posted a diagram of the headlight system as it should be in the 84 -86.
[This message has been edited by fierofool (edited 05-21-2017).]
Stubby79
Total ratings: 58
Report this Post05-21-2017 08:37 AM Click Here to See the Profile for Stubby79Send a Private Message to Stubby79Edit/Delete MessageReply w/QuoteDirect Link to This Post
Trace the wiring from the motors. If it leads to relays, you've got your explanation. If it leads to a module, you will have to diagnose the issue.
Heck, if you have a third wire siting there doing nothing at each motor, you've probably not got a module.
Chris Eddy
Report this Post05-21-2017 09:48 AM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Still not sure if the controller is gen 1 or gen 2..
So the location of the Gen 2 module is somewhat obscure, and you need to know the details. It is between the left plastic quarter panel and the metal inner skin. It is not visible without taking stuff apart. Wires go into a hole in the metal skin, and plug into the module. There are two mounting screws that you can probably see coming through the metal.
Assuming that it is Gen 2.. which came in in what year? 87??
One way to get to the module is to take the left tire off, and remove the plastic wheel liner. You can then see the module. Probably 7mm at a right angle could then remove it.
If you pop it apart, to see the PC board, you might be able to see if it is burnt. When burnt, the area around the two transistors (black rectangle with metal tab) are usually browned or burnt.
Report this Post05-22-2017 06:06 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
If Gen2 then
1. Module WILL shut down for any problem(s) w/ the motor or lift/door assembly. The module contains 2 sections to control each motor separately so one door can work w/ other w/ problems.
See my Cave, Gen 2 HL Motor
If door or lift are binding then fix the problem but Do Not lube w/ anything wet. Oil etc can attack the dry plastic bearings and hold dirt too.
"Dry" lubes can cause plastic problems too. Spray the steel not others and let it dry. (Teflon types often have strong solvents etc. Aluminum and plastic parts often doesn't like Graphite.)
Examples:
~4 Plastic bearings in the lift and 1 or all maybe bad. (2 for bucket. 1 or 2 for link to motor.)
4 Lift holes to mount them are adjustment points to center so HL won't hit the hood edges.
Door bearing strips hits 2 bump on back of lift then 1 or 2 more when lift is fully up. The strips or bumps maybe missing or damaged.
If motor has problems...
A. Can try to clean lube etc but may not work for long. May look like is a simple design but small errors to fix them can be problems down the road.
B. Replace w/ NEW Cardone motor(s) and be done w/ them.
2. Motor's pins, gear and/or output shaft has broken...
Best bet is replace w/ NEW Cardone motor(s) and be done w/ them.
Read https://www.fiero.nl/forum/Forum2/HTML/128600.html Is hard because some posts are Gen1 etc.
Report this Post05-23-2017 09:11 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
The only Cardones I have seen are remanufactured, which is ok.
The new ones I see cost half as much as the remans, they look like this and I wonder about the quality, anyone used some?
Report this Post05-24-2017 10:46 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
I and a few others have New Cardone units.
Works well, faster and quiet vs old OE units. Other that is not black fit is same.
Plus No Core charge for them. If you buy Rebuild online the often have to ship them back and hope you get your money. (If you get AZ and some online then I think you can return the core to the store w/ proper paperwork.)
Cardone Rebuild units should be good too but may have same noise level as factory units. Gen2 Noise is still quieter vs Gen1
I have never had problems using anything Cardone but other rebuild companies... Many items don't last and even when have a "lifetime" warranty you have to use them every few years at best. AZ and others have very good warranty systems just using a phone # but Pepboys and others have many ways to say no when you don't have a receipt. (AZ Advance and some others had this long before any bonus/loyalty card programs.)
As a side note: FMVSS 108 says any popup must open in ≤ 3 seconds. OE Gen2 units are ~ 2 seconds and Cardone new units are close to 1 second to open. (If Gen2 is slow first check front grounds to car's body, G101 and G102.)
S12. Headlamp Concealment Devices. 12.5 ... each headlamp concealment device shall, within an ambient temperature range of −20°F to +120°F, be capable of being fully opened in not more than 3 seconds after the actuation of a driver-operated control.
[This message has been edited by theogre (edited 05-24-2017).]
