  Window regulator grease? What brand?
Window regulator grease? What brand? by kevin
Started on: 05-17-2017 02:20 PM
Replies: 5 (743 views)
Last post by: fierotrev2014 on 05-18-2017 09:35 AM
kevin
Report this Post05-17-2017 02:20 PM Click Here to See the Profile for kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fellas,
I tried doing a Search, but could not find what I was looking for? I am trying to make my windows go faster. I understand someone on the Forum recommended a certain type of grease (or lubricant) to use on the regulators to assist them (the) rollers move up and down faster. I want to use the best, GM? or other manufacturer's brand. I dont think white grease is recommended because it will cake over time, then you got to go back in again to clean out all the collection of muck.
Cordially,
kevin
Ps. Wasn't there another Pennock Fiero member who researched other GM regulators that can be cross-interchanged to the '85 Fiero?
[This message has been edited by kevin (edited 05-17-2017).]
Report this Post05-17-2017 03:36 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any lube can hold dirt etc...
Door is dirty to start w/ even when the window rubbers are good.
1 big issue is the rollers will "shrink" on the ball tip and won't roll.
Lube then only helps for the short term.
Dorman makes/make new rollers that some pried off dead ones then switch the new ones.
Report this Post05-17-2017 05:02 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
I've used Sil Glyde silicone grease. It worked well.
I use DuPont silicone spray lube on window Tracks.
[This message has been edited by 2.5 (edited 05-18-2017).]
viperine
Report this Post05-17-2017 06:34 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use DuPont silocone spray lube on window Tracks.
X2. I use Sil-glyde in the seat tracks as well.
mmeyer86gt/gtp
Total ratings: 73
Report this Post05-18-2017 01:20 AM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
i wonder if there is a roller bearing you can put in there in place?
fierotrev2014
Report this Post05-18-2017 09:35 AM Click Here to See the Profile for fierotrev2014Send a Private Message to fierotrev2014Edit/Delete MessageReply w/QuoteDirect Link to This Post
AC Delco makes a product called Super Lube, part# 12371287 that is used at the dealership I work at for window regulators and various other plastics and rubbers.
But if your plastics in the regulator are worn bad or gone I don't think it would help much.
