  Cummings 2.8ltr 4cyl common rail swap
Cummings 2.8ltr 4cyl common rail swap by E.Furgal
Started on: 04-03-2017 08:03 AM
Replies: 6 (254 views)
Last post by: fieroguru on 04-04-2017 08:33 PM
E.Furgal
Total ratings: 278
Report this Post04-03-2017 08:03 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone think any transaxle will live behind/beside this..
https://cumminsengines.com/repower
[This message has been edited by E.Furgal (edited 04-03-2017).]
boxen
Report this Post04-03-2017 12:01 PM Click Here to See the Profile for boxenSend a Private Message to boxenEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd be more interested to see what the RPM's are at 60mph through any of the transaxles, and what redline of that motor is.
tebailey
Report this Post04-03-2017 03:13 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Skytrak used to build a 5028 rough terrain forklift that had a 3.9 Cummins diesel with a Ford auto trans. Surprisingly those transmissions held up great.
Total ratings: 260
Report this Post04-03-2017 07:19 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
267 lb-ft is below the F40 factory rating, as well as the 02M/02Q VW transaxles, which also came behind diesels too.
So yes.
Could someone install it and break axles and transmission parts? Yes... largely impacted by driver behavior.
Hudini
Total ratings: 165
Report this Post04-03-2017 07:38 PM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
3200 rpm max as listed on your link. You would have to change gear ratios to make it run down the highway efficiently. My stock Th125c runs 3300 rpm at 70 mph with a 3.33 final drive. And with the 3.4L and turbo I'm near that 267 torque for that diesel.
E.Furgal
Total ratings: 278
Report this Post04-04-2017 03:36 AM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
I doubt there would be any going down the highway with an transaxle with o/d.. 2rd dune like buggie with much of the plastic body off..
Or. make a fiero tarr without the bodywork.. a.k.a take one roadkill vette cart.(fiero with no bodywork plastic..) and mix in one jeep and stir..
[This message has been edited by E.Furgal (edited 04-04-2017).]
Total ratings: 260
Report this Post04-04-2017 08:33 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
With a diesel engine, you are not building a race car and several transmissions would allow the engine to provide ample interstate speeds...
At 3200 rpm and with a 24.6" tire you could attain the following top speeds:
Isuzu: 94.4 mph
Getrag: 90.1 mph
F40: 106.4 mph
LHD VW 6 speed: 117.8 mph
