  What to do about the clips that hold the coolant tubes on the bottom of the car?
What to do about the clips that hold the coolant tubes on the bottom of the car? by Chris Eddy
Started on: 03-28-2017 09:12 PM
Replies: 13 (379 views)
Last post by: Blacktree on 03-30-2017 09:10 AM
Chris Eddy
Report this Post03-28-2017 09:12 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Six pics..
It is hard to see, but a lot of the clips that hold the tubes on are missing, bent, or damaged. The clip by the fuel filter is completely gone, and the tube is about 1.5" from the body in mid air.
So does anyone have any ideas on where to get hardware to fix this? I have never seen any Ebay fodder or anything on Fiero store or Rodney..
Is it safe to assume that I can just buy foam sleeveing that I can replace the missing foam for the evap lines?
Would love to know if anyone has solved this and has some suggestions..
Report this Post03-28-2017 09:45 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not hard to fabricate from sheet metal.
Or, with luck, available at upullit yards.
MRBLUE87
Report this Post03-28-2017 10:32 PM Click Here to See the Profile for MRBLUE87Send a Private Message to MRBLUE87Edit/Delete MessageReply w/QuoteDirect Link to This Post
For whatever reason GM did not supply these clamps as a replacement part and they have no part number. So, everybody please save these when you scrap a car.
MRBLUE87
Report this Post03-28-2017 10:35 PM Click Here to See the Profile for MRBLUE87Send a Private Message to MRBLUE87Edit/Delete MessageReply w/QuoteDirect Link to This Post
MRBLUE87
Member since Jan 2003
Report this Post03-28-2017 10:41 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
That style clamp is 84-87.
88 is a different design.
They are not interchangeable.
Report this Post03-28-2017 10:45 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2004
In the first picture, the plastic clamshell style clamp is missing from the heater core lines.
The bracket with the hole, between the heater lines, accepts the 10mm head self tapper that holds the clamp.
Chris Eddy
Report this Post03-28-2017 10:45 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have my eye on a u-pull near me for many items, that will add to my list..
sardonyx247
Total ratings: 219
Report this Post03-29-2017 01:32 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
We have lots if you need some, PM me if you do.
Rodney
Total ratings: 267
Report this Post03-29-2017 10:34 AM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero Store has reproduced them:
https://www.fierostore.com/...20%20%20SET&d=80&p=1
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
Report this Post03-29-2017 10:38 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those clips/clamps are for the radiator coolant tubes, O/P is looking for items on the heater core and A/C lines, on either side of fuel tank.
Rodney
Total ratings: 267
Report this Post03-29-2017 12:31 PM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I see now. My mistake. Just trying to help out Fiero owners. Check places like Firebird or Corvette parts suppliers. They may have had them reproduced if they were also used on those cars. GM tried to use common parts whenever possible.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Report this Post03-29-2017 01:02 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would think the die would be easy to make, either progressive a couple of separate dies.
Probably not that big of a market.
I have made them in just a few minutes, bending them in my vise.
ag9123
Report this Post03-30-2017 09:09 AM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I just installed a set of the coolant clamps from the Fierostore. They fit perfectly, another Fiero problem solved
1984 Indy Fiero
Blacktree
Total ratings: 350
Report this Post03-30-2017 09:10 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
A Google search for "double line clamp" turned up lots of stuff. Here's an example:
They're available in different sizes and different materials, also. Get some stainless clamps, and you'll be good to go.
