| | | quote | Originally posted by olejoedad:
Having driven both SBC and LS powered Fieros......
It's a no-brainer. LS |
x2
I had a SBC Fiero for 6 years, and I have had my LS4/F40 swap done for nearly 4 years. My goal with the switch was to gain 100 hp (382 whp vs. 282 whp), drop 100 lbs (2807 vs. 2960 lbs), and 30 mpg... I missed this one as I only reached 29 mpg, but the best with the SBC/getrag was 23 mpg.
To the OP:
Your link refers to the LM4 (a RWD LSx engines that will require an adapter plate). The LS4 is the FWD version that bolts directly to the FWD transmissions. If the wiring scares you, there are carb intakes and ignition control modules that will greatly simplify the wiring. If you get an 07+ engine, I have posted the wiring details in my linked thread earlier this this thread.
