  Do larger wheels and tires prematurely wear out the 88 front bearings?
Do larger wheels and tires prematurely wear out the 88 front bearings? by Madess
Started on: 03-19-2017 02:55 PM
Replies: 6 (245 views)
Last post by: theogre on 03-19-2017 10:46 PM
Madess
Report this Post03-19-2017 02:55 PM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
I want to get larger brakes, wheels and tires for my 88 and I was wondering if anyone has monitored if this causes faster wear of the 88 front bearings? Just curious.
Thanks
Report this Post03-19-2017 06:56 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think it would be hard to prove one way or another. Too many variables. I suspect increased weight would shorten bearing life.
Report this Post03-19-2017 07:19 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm thinking that if you have the same offset wheels as factory wheels, and the fact that the wheels and tires are unsprung weight, there's no extra load on the bearings. There might be a little advantage to a larger diameter tire because over the life of the tire and their replacements, the number of rotations per mile would be reduced as compared to going with a stock or smaller than stock tire.
Madess
Report this Post03-19-2017 08:43 PM Click Here to See the Profile for MadessSend a Private Message to MadessEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess the question was more along the lines of if your bearings were fine, did they go south shortly after you put larger wheels and tires on your car?
FieroLost
Report this Post03-19-2017 09:36 PM Click Here to See the Profile for FieroLostSend a Private Message to FieroLostEdit/Delete MessageReply w/QuoteDirect Link to This Post
With larger (width) wheels and larger brakes, more force would or could be applied to the bearings. The bearings are the weakest part of the Fiero, and were not designed for the performance (forces) that upgraded wheels and brakes could transfer to bearings. Occasionally utilizing the increased performance available, as in evasive maneuvers, may be tolerated by the bearings. But, sustained performance (aggressive) driving would impact negatively the life of the bearings. So cornering or braking forces that regularly exceed the design limits of the bearings, will ultimately contribute greatly to the bearings early demise. Just as, if you tighten a fan belt beyond the recommended limit, the alternator or fan belt pulley bearings will prematurely fail.
It is my understanding.
[This message has been edited by FieroLost (edited 03-19-2017).]
Total ratings: 463
Report this Post03-19-2017 10:45 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anything that results in a larger "footprint" and/or more grip in a turn is going to be harder on the bearings.
[This message has been edited by Patrick (edited 03-19-2017).]
Report this Post03-19-2017 10:46 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Basically correct.
You don't have to add bigger tires to cause wheel bearing failure. Includes +1/-1 tires w/ very close to same overall tire width and diameter like OE is 14" rim w/ 195/70 but new 15" rim w/ 205/60 w/ same offset etc.
Example: Autocross can break a lot of wheel bearings for many cars w/ stock wheels. Break outright or a week or more after racing.
Aftermarket bearings have problems too. This is covered before. Use Search.
