Neils88 that is what I need but for 84-87.
Have to look, but I think there is a center drill point in the rear of the spindle shaft. Where they would set it up in a lathe while turning.
From that center, to the center of one of the caliper bracket mounting holes.
Measured the caliper, bracket with pads today, that i am trying to use.
The caliper application calls for a rotor that is 11.4" with working thickness 18.5-20.5 mm/ Which works very close to the LeBaron rotor.
However the measurements I had taken today shown. Pad maximum 26mm with new pads. 26 mm between hardware and 27.5 between the bracket. Which makes up to a 24mm width rotor possible.
This makes for a lot more options. Though the centers would have to be machined, there are several Toyota and Subaru rotors that fit the bill. 275-312mm diameter 10.8"-12.2". With hat depth within 4mm of the 9.7" Grand AM hats.
The pad surface is close to stock Fiero. Maybe 5% less, but thicker and without the odd "ears" on the outer pad. Also the caliper does not hold the pads, the bracket does. This setup tends to wear better in my many years of observation.
The bracket mounting holes are 76mm (very close to stock Fiero) apart and 62-65 mm usable area from the center of the mounting holes to the outside.
10mm offset to the outside on the brackets.
Depending on the curvature of the pads and the distance of the spindle center to caliper mounting points, this may be an easy swap for the GM Grand Am, Berreta performance rotors at 10.25
However the caliper bracket is not tapped and would need to be and the Fiero caliper bracket threads drilled out for a spacer bolt on.
The calipers and brackets fit rear S10 from 1998 to 2003. All have 48mm pistons. Some use staggered arrangement so you would need to make sure to get non staggered application. Varies by year and 2WD and 4WD.
I had did some preliminary measurements off a 2001 Blazer 2WD last week. They were non staggered (proper bleeder arrangement left/right).
The one thing that may not make this work is the brake line interference.
[URL=http://www.ebay.com/itm/Completely-New-Rear-Right-Brake-Caliper-18B4713-fits-98-04-Chevy-S10-Olds-GMC-/172252298578?fits=Make%3AChevrolet%7CModel%3AS10&hash=item281b097d52:g:zVQAAOSw4DJYf1vF&vxp=mtr]http://www.ebay.com/itm/Com...AOSw4DJYf1vF&vxp=mtr[/ URL]
Some other stuff those spindles were used on.
http://ozgemini.com/forums/...328&highlight=fiero.[This message has been edited by cmechmann (edited 01-31-2017).]
