  Changing drive gears in 4T65e to 3.69 ratio
Changing drive gears in 4T65e to 3.69 ratio by darbysan
Started on: 01-26-2017 03:38 PM
Replies: 7 (2463 views)
Last post by: Lou6t4gto on 02-13-2017 06:20 PM
darbysan
Report this Post01-26-2017 03:38 PM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm considering changing the internal chain gears in my 4T65e from 37/33 to 33/37, giving me a final drive ratio of 3.69 ( vs the 2.93 I have stock). I've done a lot of reading and searching over the net, and while it looks doable, there are some folks that are negative about such a change.
The reason I am considering the change is I would like more performance at lower speeds- around town driving mostly. I do take an occasional road trip, but the gas mileage lost is not a big concern. I have 3.73 now in my El Camino, and I know that going from 3.08 to 3.73 was like installing a new engine!
Anyone done this? Any constructive ideas? I've located a set of gears for a good price, and the gaskets are readily available. I've found this thread on changing out the 4th clutches, which is pretty much the same procedure needed for the gear swap.
Transmission side cover removal 4T65e
I assume that I will have to drop the cradle for access, but wondered if anyone has done this in the vehicle. While tight, it looks doable??
I know that the PCM will need re-programming. I have access to a Power Tuner, and there are a couple of variables that are readily shown: Calculated Pulses per Rev, Pulses per mile, Drive Sprocket Ratio. I've gotten some info on these, but it is sort of confusing. There are also a ton of tables with shift points, and I assume that all of them need to be looked at and modified. I doubt that the power tuner is sophisticated enough to automatically change all of the tables based on a gear change ( maybe someone knows??). This is probably a task for Ryan, and one he may have done before. Maybe he will chime in.
Lastly, since I will have it open, should I add a Transgo Shift Kit while it is out? Vehicle has the Trans Performance Shift button enabled already.
Be glad to hear your thoughts... ( be kind!)
'87 GT , '00 3800 Series II SC, 4t65e.
nosrac
Total ratings: 51
Report this Post01-26-2017 11:32 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
ZZP, Grand Prix Forum, or HP Tuners forum will get you the necessary inputs for 3.69 gears. I have a gear change spreadsheet. PM or Email for details.
3.69 gears will really wake up the car in the 1/4 mile sprint. Talk to some grand prix guys and I don't think you will be disappointed.
I plan on getting some when I go to a built trans as I don't care about MPG I only care about acceleration..
Total ratings: 328
Report this Post01-27-2017 06:22 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
As you alluded to; if you change the FDR , the PCM program shift table will need to be modified relating to the speed and RPM's that it references. Tire diam will also factor in. Without reprogramming the transmission will short shift and can result in lugging and possible transmission failure. Unfortunately its not as simple as changing the drive gears and chain. Its a tricky process.
[This message has been edited by Dennis LaGrua (edited 01-28-2017).]
FIEROFLYER
Total ratings: 180
Report this Post01-28-2017 09:05 AM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
the 97 Z34 monte came stock with 369 gears in the 4T65E tranny only with the 3.4 DOHC engine making it another tranny with the gears and programming that match. mind you it is shift points for the 3.4 but still a start
darbysan
Report this Post02-03-2017 12:38 PM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found this information (below) on programming while searching the net. I checked my DHP editor and it seems I have access to most of these items. A rough estimate shows about 69 tables, with about 1200 individual parameters. Most of the parameters are in MPH.
I'm thinking that a change from 2.93 to 3.69 would result in MPH at a given rev dropping by 26%, so if I reduce all of the MPH's in these tables by 26%, I should be in the ballpark. I'm also thinking I could program the "Normal " mode with the same parameters as the "performance" mode, eliminating the need for the switch.
Anybody done this with the DHP tuner? Or does this need HP tuners or Tunercat? As always, look forward to your thoughts.
CALIBRATIONS PARAMETER DIFFERENCE SUMMARY REPORT
Source Calibration File: D:\Profiles\wltm07\My Documents\BINs\97_Grand_Prix_3100_16243385_speedo.cal
Compare Calibration File: D:\Profiles\wltm07\My Documents\BINs\97_Grand_Prix_3100_16243385.cal
Total Parameters Compared: 522
Total Differences Found: 26
Constants
Transmission Parameters
2->3 Upshift Vehicle Speed In Drive 2
3->2 Downshift Vehicle Speed In Drive 2
1->2 Upshift Vehicle Speed In Drive-Low
2->3 Upshift Vehicle Speed In Drive-Low
2->1 Downshift Speed In Drive-Low
3->2 Downshift Speed In Drive-Low
System Parameters
Speedometer Input Pulses Per Revolution
Speed Pulses Per Mile
Trans Output Shaft Revs Per Mile
Tables
Transmission Tables
Normal Mode Shift Speed (MPH) Vs. %TPS Vs. Shift
Performance Mode Shift Speed (MPH) Vs. %TPS Vs. Shift
Cruise Mode Shift Speed (MPH) Vs. %TPS Vs. Shift
Hot Mode Shift Speed (MPH) Vs. %TPS Vs. Shift
Normal Mode WOT Shift Speed Vs Shift
Performance Mode WOT Shift Speed Vs. Shift
Hot Mode WOT Shift Speed Vs Shift
1->2 Upshift Speed Vs. TPS - In Drvie 2
2->1 Downshift Speed Vs. TPS - In Drvie 2
Normal Mode TCC Apply Speed (MPH) Vs. %TPS Vs. Gear
Normal Mode TCC Release Speed (MPH) Vs. %TPS Vs. Gear
Performance Mode TCC Apply Speed (MPH) Vs. %TPS Vs. Gear
Performance Mode TCC Release Speed (MPH) Vs. %TPS Vs. Gear
Cruise Mode TCC Apply Speed (MPH) Vs. %TPS Vs. Gear
Cruise Mode TCC Release Speed (MPH) Vs. %TPS Vs. Gear
Hot Mode TCC Apply Speed (MPH) Vs. %TPS Vs. Gear
Hot Mode TCC Release Speed (MPH) Vs. %TPS Vs. Gear
FIEROFLYER
Total ratings: 180
Report this Post02-06-2017 04:17 PM Click Here to See the Profile for FIEROFLYERSend a Private Message to FIEROFLYEREdit/Delete MessageReply w/QuoteDirect Link to This Post
A friends 97 Monte still has the 369 geared tranny and a 3800SC that we installed and it is running fine, all programming was done with my power tuner.
darbysan
Report this Post02-07-2017 10:20 AM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the input. Does my approach of changing the shift point files mentioned above by 26% seem like a logical starting point, or am I just re-inventing the wheel? Would I be better served buying a tune that has already been accomplished? ( I have plenty of time- retired engineer. So spending hours adjusting tables is not an issue).
Lou6t4gto
Report this Post02-13-2017 06:20 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
anyone Know if the Grand Prix "Daytona" had more desirable gearing (as far as 1/4 Mile is concerned?? Thanks
