  17x8 tire size wcf coilover
17x8 tire size wcf coilover by MaxwellSpy
Started on: 01-21-2017 09:46 AM
Replies: 6 (429 views)
Last post by: Spadesluck on 01-26-2017 07:52 AM
MaxwellSpy
Report this Post01-21-2017 09:46 AM Click Here to See the Profile for MaxwellSpySend a Private Message to MaxwellSpyEdit/Delete MessageReply w/QuoteDirect Link to This Post
What tire size would yall run for 17x8 35mm offset? The car has the wcf coilovers in the back and wcf springs in the front. Would like low profile tires as well.
Thanks for any input!
Total ratings: 260
Report this Post01-21-2017 11:29 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am running 17x8 front wheels with 235/40/17 tires (24.4" diameter). I wouldn't run a tire any thinner than 235 unless you like the stretched look. Several mfg offer a 245/40/17 (24.7" diameter).
MaxwellSpy
Report this Post01-21-2017 11:38 AM Click Here to See the Profile for MaxwellSpySend a Private Message to MaxwellSpyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply! What are you running in the back?
Total ratings: 260
Report this Post01-21-2017 12:45 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Front: 17x8 45et with 235/40/17
Rear 18x9.5 45et with 285/30/18
The front is a very tight fit on an 88 and the rear took a little more work and is even tighter.
[This message has been edited by fieroguru (edited 01-21-2017).]
Blacktree
Total ratings: 350
Report this Post01-21-2017 12:58 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
On a 17x8" wheel, I'd go for 245/40-R17. What size are the front wheels and tires?
Spadesluck
Report this Post01-26-2017 03:39 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
To run a 17x8 rim with a 245 tire, does one need to run a coil over in the back or will a wheel spacer work?
Spadesluck
Report this Post01-26-2017 07:52 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spadesluck
Member since Jul 2016
NM, after doing some homework I found my answer. Yes, for anything 245 and larger you will need coil overs with the spring perch cut.
