  Found the right LED for the instrument cluster
Found the right LED for the instrument cluster by Chris Eddy
Started on: 01-11-2017 02:27 PM
Replies: 8 (625 views)
Last post by: Patrick on 01-12-2017 04:26 PM
Chris Eddy
Report this Post01-11-2017 02:27 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have been trying different LEDs, trying to get my dash to brighten up.
I tried the LED to the left in this picture.. it did not help.
I tried the LED to the right in this picture.. and it works much better.
The speedo and tach are much better, easy to read at night. The center items (gas temp) are still hard to read, probably hopeless.
They dim up and down with a brightness similar to the radio HVAC.
I tried to take pics of the instruments in the dark, but they come out terrible.
So you will need 6 of these.. do not put them in the center group of indicators, as they have different colors, and need an incandescent.
The paint on the back of the panel is bright orange.. I chose red LEDs, as they are the closest to the orange, could not find orange LEDs in this style.
They must be 12V, and are described as a T10 base. The sockets that came with them were tight, so I kept the grey ones that were OEM.
They have polarity.. do this with power on. If an LED does not work, switch it around, and it will then.
Heerza link to the page that I bought them off of..
[url=Leds on Aliexpress]https://www.aliexpress.com/item/10pcs-T10-W5W-12V-Led-Auto-Bulb-With-Twsit-Lock-Led-Dashboard-Instrument-Panel-Light-For/32375362855.html?spm=2114.13010608.0.0.PZAKuG[/url]
[This message has been edited by Chris Eddy (edited 01-11-2017).]
tshark
Total ratings: 68
Report this Post01-11-2017 07:00 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Chris Eddy
Report this Post01-11-2017 07:51 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did not know about BTR.. not sure what that is.
tshark
Total ratings: 68
Report this Post01-11-2017 10:41 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Chris Eddy
Report this Post01-12-2017 10:02 AM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I suppose that I am proposing a simple fix that anyone can order, for less than $8, and the instruments are retained with no sign of switching things out. For the purist (or cheapskate).
And your woman will be so impressed with the upgrade.
Report this Post01-12-2017 11:46 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finding LED that works isn't only issue.
6 194 bulbs are bright normally.
Dimmer full on and still have Dim light then something is wrong.
worse, bright dash and others in the cabin is light pollution and negatively affects driving at night, more so when outside of city downtown w/o streetlight etc.
I never have dashes w/ lights full on for this reason. Many New cars have lights you can't dim enough or worse have OE or Aftermarket LCD displays you can't dim or turn off.
Mickey_Moose
Total ratings: 145
Report this Post01-12-2017 01:29 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
From another hobby of mine - most colors and varying brightness and styles available:
http://www.pinballbulbs.com/pinball-leds
http://www.cometpinball.com/category-s/1841.htm
They have orange, but orange tends to not be as bright as the other colors. Here is a helpful list of the colors listed from brightest to dimmest and alternative colors to use instead. Myself, I have used cool whites in the cluster - red makes it way to red for my tastes. http://www.pinballbulbs.com...talls/gi-kit-install
[This message has been edited by Mickey_Moose (edited 01-12-2017).]
Chris Eddy
Report this Post01-12-2017 04:03 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ogre, I have heard your position before.. but honestly, if I cannot see the numbers at night (my vision is fine), and now I can.. isn't that a fix?
And for light pollution, if they are bright enough, and I can now dim them (including radio and HVAC) then I have control over that situation.
Really though, I can just see them clear enough to know exactly what the numbers are. So I would not say that I have them too bright.
Wish I could get a good set of pictures of this.. but at night, it is really hard to get useful ones.
"Honest officer, I have no idea how fast I was going. And it's GM's fault!"
And I am also a Pinball fanatic, so I did have a starting point on these style bulbs. They are 6V.. but have the same base (a 555 does).
Total ratings: 465
Report this Post01-12-2017 04:26 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I buy blue LED bulbs (it's more of a bluish-white) for interior lighting and for over the rear license plate. Can't beat the price Here... 20 bulbs for less than six bucks, with free shipping!
