  3800SC N* LQ4 Tuning
3800SC N* LQ4 Tuning by nosrac
Started on: 01-10-2017 10:41 AM
Replies: 5 (588 views)
Last post by: nosrac on 01-12-2017 03:42 PM
nosrac
Total ratings: 51
Report this Post01-10-2017 10:41 AM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
4 different MAF tables...WTH?
stock z06
1.422 1.758 2.102 2.484 2.859 3.258 3.695 4.180 4.711 5.313 5.969 6.680 7.430 8.227 9.078 9.969 10.914 11.930 13.055 14.273 15.586 16.984 18.469 20.047 21.719 23.477 25.336 27.281 29.336 31.484 33.742 36.109 38.617 41.297 44.172 47.203 50.398 53.766 57.297 61.008 64.875 68.914 73.117 77.469 81.969 86.633 91.453 96.430 101.586 106.898 112.359 118.008 123.828 129.844 136.047 142.477 149.125 155.984 163.063 170.375 177.922 185.703 193.727 201.992 210.516 219.297 228.336 237.641 247.227 257.063 267.164 277.563 288.250 299.250 310.555 322.195 334.156 346.492 359.164 372.219 385.656 399.508 413.766 428.453 443.602
Standard
1.476563 1.796875 2.132813 2.492188 2.890625 3.328125 3.796875 4.34375 4.90625 5.539063 6.21875 6.953125 7.726563 8.5625 9.453125 10.38281 11.38281 12.45313 13.60156 14.85156 16.21094 17.70313 19.32031 21.02344 22.77344 24.53906 26.42969 28.40625 30.49219 32.65625 34.95313 37.35938 39.89844 42.61719 45.47656 48.5 51.65625 54.97656 58.4375 62.04688 65.82031 69.72656 73.79688 78.03125 82.40625 86.9375 91.63281 96.49219 101.5078 106.7109 112.0938 117.6328 123.3516 129.2422 135.2969 141.5313 147.8672 154.4063 161.1484 168.0781 175.2188 182.5781 190.2266 198.2109 206.2422 214.7969 223.5234 232.5234 241.8281 251.3438 261.1328 271.1875 281.5313 292.1484 303.0469 314.25 325.7266 337.5078 349.5938 361.9609 374.6406
RWC
1.476563 1.796875 2.132813 2.492188 2.890625 3.328125 3.796875 4.34375 4.90625 5.539063 6.21875 6.953125 7.726563 8.5625 9.453125 10.38281 11.38281 12.45313 13.60156 14.85156 16.21094 17.70313 19.32031 21.02344 22.77344 24.53906 26.42969 28.40625 30.49219 32.65625 34.95313 37.35938 39.89844 42.61719 45.47656 48.5 51.65625 54.97656 59.4375 63.04688 66.82031 71.72656 75.79688 80.03125 85.40625 89.9375 94.63281 99.49219 104.5078 109.7109 115.0938 120.6328 126.3516 132.2422 138.2969 144.5313 150.8672 158.4063 165.1484 172.0781 179.2188 186.5781 194.2266 202.2109 210.2422 218.7969 227.5234 236.5234 245.8281 255.3438 265.1328 275.1875 285.5313 296.1484 307.0469 318.25 329.7266 341.5078 353.5938 365.9609 378.6406
Suburban
1.594 1.875 2.203 2.578 2.992 3.445 3.953 4.500 5.102 5.758 6.461 7.234 8.063 8.953 9.898 10.906 11.977 13.141 14.391 15.742 17.188 18.742 20.391 22.141 23.992 25.945 27.992 30.141 32.375 34.711 37.164 39.734 42.500 45.414 48.469 51.672 55.016 58.484 62.102 65.859 69.766 73.820 78.063 82.484 87.070 91.820 96.742 101.820 107.078 112.484 118.070 123.828 129.758 135.867 142.172 148.609 155.258 162.109 169.172 176.438 183.938 191.719 199.805 208.063 216.617 225.438 234.523 243.891 253.453 263.211 273.234 283.547 294.148 305.063 316.320 327.930 339.922 352.320 365.156 378.469 392.297 406.703 421.703 437.344 453.688
Darth Fiero
Total ratings: 361
Report this Post01-10-2017 04:23 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tell me about it. GM used different MAF calibrations in many different applications that use the exact same part number MAF sensor. I never understood it myself. The only thing I can think of is final MAF tweaking was done by the factory for each specific application to dial in the fuel and that's where they left it. So, as you can imagine, it isn't going to be a simple matter of just cutting and pasting a MAF calibration table from another tune into yours. You are going to have to dial it in yourself.
[This message has been edited by Darth Fiero (edited 01-10-2017).]
Total ratings: 328
Report this Post01-10-2017 04:39 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe that the different calibrations of the same MAF sensor may have to do with the way the intake air tubes and TB's were sized and configured. The length and bends all can influence the way the air flows.
Must 100% agree that you just can't cut and paste a MAF table for a specific sensor and expect it to be plug and play. But you can monitor the MAP, LTFT's and O2 sensor readings as related to RPM and tweak the MAF curve with small changes here and there. According to the tune that I did, I found small changes can make a big difference.
Total ratings: 461
Report this Post01-11-2017 11:13 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't imagine that any stock LQ4 tables, for such a different application, would just "plug in". I would expect to have to tweak any/all of them.
I was pleasantly surprised when I copied tables over from one BIN to another (way different application) and they actually worked decently.
[This message has been edited by Raydar (edited 01-11-2017).]
Total ratings: 328
Report this Post01-12-2017 10:32 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use the early LS1 MAF on my swap and importing the V8 MAF table got the engine started and it ran. The calibration was somewhat close. Now with the wide difference in the LQ4 MAF values shown above, I would say that its doubtful that they all can be plug and play. I'd pick the one closest to the engine size that you are running and go from there.
[This message has been edited by Dennis LaGrua (edited 01-12-2017).]
nosrac
Total ratings: 51
Report this Post01-12-2017 03:42 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Believe it or not these are all close enough MAF tunes that will run the car good but not great. There are many people with mail order tunes that have good running cars.
However, when you want to maximize performance, MPG, etc you need a custom tune.
Hell even the custom tunes need to tweak in the winter and summer because of different fuel blends ad weather patterns.
