  Power window motor replacement? How?
Power window motor replacement? How? by James Lloyd
Started on: 01-04-2017 08:04 PM
Replies: 11 (828 views)
Last post by: James Lloyd on 01-31-2017 03:51 PM
James Lloyd
Report this Post01-04-2017 08:04 PM Click Here to See the Profile for James LloydSend a Private Message to James LloydEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have searched high and low for a "how to" on replacing window motors. I've used the search function and I've used google. Neither have yielded anything useful. If any one could direct me to an instructional thread or provide a link or even their own how to, I'd appreciate it very much.
Report this Post01-04-2017 08:18 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
does this help? It's for installing power windows to a manual car, but you could ignore a lot of it.
http://www.michiganfieroclub.com/files/power.pdf
[This message has been edited by Gall757 (edited 01-04-2017).]
James Lloyd
Report this Post01-04-2017 08:27 PM Click Here to See the Profile for James LloydSend a Private Message to James LloydEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well it fills in a few blanks. But it leave a lot to be desired.
tshark
Total ratings: 68
Report this Post01-04-2017 08:28 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
James Lloyd
Report this Post01-04-2017 08:39 PM Click Here to See the Profile for James LloydSend a Private Message to James LloydEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have nearly enough funding to replace all the parts you're suggesting. I just need the old motor out and the new motor in.
Report this Post01-04-2017 08:53 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
OK use the old parts. You can even use nuts and bolts instead of rivets, but watch out for clearance issues and hope they don't get loose later.
Total ratings: 260
Report this Post01-04-2017 09:12 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Neils88
Total ratings: 56
Report this Post01-04-2017 09:17 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here is the link to my thread where I converted a manual window to power windows. You won't need that part, but I documented every step for removal of the regulator. This might help you.
https://www.fiero.nl/forum/Forum2/HTML/133353.html
[This message has been edited by Neils88 (edited 01-04-2017).]
tshark
Total ratings: 68
Report this Post01-04-2017 11:36 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spadesluck
Report this Post01-27-2017 08:52 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
To help with that switch failure you can use relays or this Window Helper
[This message has been edited by Spadesluck (edited 01-27-2017).]
Total ratings: 328
Report this Post01-30-2017 10:35 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I may chime in; be sure to replace the window motor with a quality HD unit. The cheaper Chinese units sold on eBay will work but raise the window slowly and will not last long. My son installed one on his Silverado and after 1 year it burned out. Replaced with AC Delco unit and problem solved. There is all kinds of crap being sold out there and if you can find an AC Delco unit that's probably the best bet.
James Lloyd
Report this Post01-31-2017 03:51 PM Click Here to See the Profile for James LloydSend a Private Message to James LloydEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought the window motor from the Autozone I work at. Brand new Cardone unit with a lifetime warranty.
