  4T65E-HD tranny
4T65E-HD tranny by Ryanap333
Started on: 12-30-2016 09:19 PM
Replies: 11 (465 views)
Last post by: Darth Fiero on 01-06-2017 03:49 PM
Ryanap333
Report this Post12-30-2016 09:19 PM Click Here to See the Profile for Ryanap333Send a Private Message to Ryanap333Edit/Delete MessageReply w/QuoteDirect Link to This Post
What you cause my transmission to sometime behave like its shifting into third and fourth at to low an RPM consequently lugging the engine.
Total ratings: 328
Report this Post12-30-2016 11:28 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
There could be a few causes but do you have a 3800SC swap??? If so was the PCM programmed for tire size/transmission settings?
Ryanap333
Report this Post12-31-2016 03:19 AM Click Here to See the Profile for Ryanap333Send a Private Message to Ryanap333Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes the 3800sc swap. I got my pcm from sinister. You think its electrical then?
Darth Fiero
Total ratings: 361
Report this Post12-31-2016 03:33 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Need more info. Shift tables are governed by TPS % and vehicle speed. At very low throttle opening, it is possible the transmission may upshift into a higher gear at lower speeds. You may also have the TCC engaging earlier than anticipated which would further drag down engine RPM.
Bottom line is you are going to need to connect a scan tool to the PCM so you can view live scan data showing throttle opening % and vehicle speed, as well as current trans gear and TCC lock status info. With this data, I will be able to look at the tune I made for you and determine if something is wrong or not.
-ryan
More is more. Less is not enough.
Ryanap333
Report this Post01-01-2017 04:10 PM Click Here to See the Profile for Ryanap333Send a Private Message to Ryanap333Edit/Delete MessageReply w/QuoteDirect Link to This Post
Neither of my scan tools show FCC. Until I get one I have a couple of things to point out. First, when shifting into second under heavy load the transmission has a stutter at the shift point and my not shift. Second, when cruising at highway speed thetranny slips just a little like one or two hundred rpm for a very short time and then catches over and over. Third, the time between shifts seem rather long. And fourth, the engine sometimes shift into drive and over drive and seemingly lugs the motor. If its the FCC solenoid or something requiring tranny work do I have to drop the cradle? Can I remove the tranny from the car while mounted up in the car?
Total ratings: 291
Report this Post01-01-2017 09:35 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Almost all agree this is the hard way to do this.
In my opinion, it's a major pain. It's so much easier to just drop the entire cradle.
Darth Fiero
Total ratings: 361
Report this Post01-02-2017 03:25 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like an internal transmission problem (ie: worn out clutch packs, failing pressure control solenoid, etc). Scan data showing PCS actual amperage at the shift and what the recorded shift time is might be helpful.
The TCC is designed to slip a little bit at all times while it is applied in these applications. When you are cruising at a steady speed, the actual slip RPM of the TCC clutch should be around 20 rpm or so. If you apply a little throttle, the slippage may flare up to 100-200 rpm but should quickly come back down as the PCM applies more TCC pressure. THIS IS NORMAL OPERATION.
Again, sounds like an internal transmission problem (ie: worn out clutch packs, failing pressure control solenoid, etc). Scan data showing PCS actual amperage at the shift and what the recorded shift time is might be helpful.
What you are describing here might actually be normal operation that would occur in a stock vehicle. BUT I need to know exact MPH and TPS% values when these shifts are occurring so I can determine if there is a malfunction or not. If this does turn out to be normal operation and you simply don't like it, we can change the tune to delay these upshifts a bit so they don't occur "so early".
Ryanap333
Report this Post01-03-2017 01:48 PM Click Here to See the Profile for Ryanap333Send a Private Message to Ryanap333Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well seen as how I'm going to wind up pulling the tranny and sending it to zzp i might as well get my blower ported and upgrade the rockers. Do I need an intercooler too? How easy are them cams?
Darth Fiero
Total ratings: 361
Report this Post01-04-2017 12:58 AM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check out www.tripleedgeperformance.com for the transmission build.
Lou6t4gto
Report this Post01-04-2017 01:52 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I built a bunch of them. sounds like the clutches, or hydraulic pressure. any codes showing up ? whats the fluid look like ?
Ryanap333
Report this Post01-04-2017 08:31 AM Click Here to See the Profile for Ryanap333Send a Private Message to Ryanap333Edit/Delete MessageReply w/QuoteDirect Link to This Post
Only code I get is 131 O2 sensor slow. The fluid is about three months old and looks new. Yesterday I drove it 20 miles normal driving. I only got on it enough to get 4psi of boost. The transmission didn't act up at all so it apparently doesn't act upmall the time. I doubt it would have shifted correctly from first to second if I had really got on it.
Darth Fiero
Total ratings: 361
Report this Post01-06-2017 03:49 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be a PCS issue. I've seen them cause intermittent problems just before they totally fail. Unfortunately, the side cover has to come off to access it, which can rarely be done in the car.
But then again, it could be a lot of other things. Without seeing some detailed scan data, I can't offer a better diagnosis.
