  88 Parking break lever
88 Parking break lever by rennaizxance
Started on: 12-28-2016 10:01 AM
Replies: 5 (541 views)
Last post by: theogre on 12-28-2016 02:37 PM
rennaizxance
Report this Post12-28-2016 10:01 AM Click Here to See the Profile for rennaizxanceSend a Private Message to rennaizxanceEdit/Delete MessageReply w/QuoteDirect Link to This Post
My brakes were not doing too well at stopping so I intended to swap out the components. I got rebuilt brakes from rockauto since the fiero store is out of them for now and I can't wait for the turnaround time for them to rebuild mine.
The trouble is that rockauto sent me two calipers with the same parking brake lever. Would it be possible to just swap out the lever from the old caliper without messing things up? If so is there anything specific that I need to do to make sure I don't damage anything in there?
Total ratings: 466
Report this Post12-28-2016 11:22 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are the calipers themselves different, or did you get sent two for the same side?
rennaizxance
Report this Post12-28-2016 12:18 PM Click Here to See the Profile for rennaizxanceSend a Private Message to rennaizxanceEdit/Delete MessageReply w/QuoteDirect Link to This Post
They are both for the driver's side it seems, but I'm basing that on the lever that is on them. . Is there anything internal that would prevent them from being swapped to the other side by changing out the lever?
css9450
Total ratings: 87
Report this Post12-28-2016 01:18 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you have two of the same caliper, instead of Left and Right, you don't want to put the wrong one on there because by doing so the bleeder will be on the bottom and you'll have awfully spongy brakes, at best.
rennaizxance
Report this Post12-28-2016 01:46 PM Click Here to See the Profile for rennaizxanceSend a Private Message to rennaizxanceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok thanks, I figured there was some reason for them not to be used across sides.
Report this Post12-28-2016 02:37 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
left side will never work on right and other way around. Piston guts are different.
Return is only option.
