  aftermarket oil pressure gauge install
aftermarket oil pressure gauge install by Atlanta1
Started on: 11-16-2016 08:26 AM
Replies: 11 (883 views)
Last post by: Atlanta1 on 12-26-2016 09:19 PM
Atlanta1
Report this Post11-16-2016 08:26 AM Click Here to See the Profile for Atlanta1Send a Private Message to Atlanta1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am looking to change my oil pressure gauge and volt gauge in my 87 . Do I have to
replace the oil sending unit with the new gauge sender?any particular brands
work?
Lou6t4gto
Report this Post11-17-2016 02:32 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
if You're going to change Gauges, Why not use Mechanical ?
Atlanta1
Report this Post11-17-2016 08:20 PM Click Here to See the Profile for Atlanta1Send a Private Message to Atlanta1Edit/Delete MessageReply w/QuoteDirect Link to This Post
All I want is to change the gauges to a round design
rogergarrison
Total ratings: 551
Report this Post11-18-2016 03:15 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pretty sure if you use an aftermarket electric gauge, you can use existing wires. You prob have to use the sensor that comes with the gauge. Most are calibrated together. If you go to a mechanical gauge, which will look exactly the same, you dont need any wiring. You do have to change the engine sensor. Then you just run the 1/8" tubing (brass or plastic) between the two. Mechanical eliminates any kind of false readings and gives you instant real pressure reading without having to trust the electronics.
Blacktree
Total ratings: 350
Report this Post11-18-2016 06:13 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are aftermarket gauges that can work with the stock oil pressure sender. The signal is 0-90 Ohms. (0 is zero, 90 Ohms is about 80 PSI)
I personally would not want a mechanical oil pressure gauge. But that's just me.
CrazyDragn
Report this Post11-19-2016 12:38 PM Click Here to See the Profile for CrazyDragnSend a Private Message to CrazyDragnEdit/Delete MessageReply w/QuoteDirect Link to This Post
Which one's?
Notchie to Fast Back Conversion
After Market Steering Wheel Conversion
rogergarrison
Total ratings: 551
Report this Post11-20-2016 02:51 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, its just personal choice. I just think mechanical one is pretty much foolproof/ reliable. Electric oil gauge is just slightly better than an idiot lite.
[This message has been edited by rogergarrison (edited 11-21-2016).]
Atlanta1
Report this Post11-20-2016 05:27 PM Click Here to See the Profile for Atlanta1Send a Private Message to Atlanta1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am looking at the bosch electronic oil pressure gauge comes with its own sender hope it can fit
to the fiero oil sending unit connector . Also i am trying to make my own 2 gauge pod that
will be flush instead being above dash.
Atlanta1
Report this Post12-14-2016 07:51 AM Click Here to See the Profile for Atlanta1Send a Private Message to Atlanta1Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a Bosch electronic gauge with a 2 pin connector the fiero has a 3 pin connector for its sending unit.
has anyone installed one of these gauges? it comes with its own sending unit. I can retain
my warning light with a T-connector.
fierosound
Total ratings: 286
Report this Post12-14-2016 10:42 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
[This message has been edited by fierosound (edited 12-14-2016).]
Atlanta1
Report this Post12-17-2016 05:45 PM Click Here to See the Profile for Atlanta1Send a Private Message to Atlanta1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Guys I just pulled my oil and volt gauge out and it is tied to one plug that fits for both
how can I separate into two new gauges like a new bosch and oil gauge?
Atlanta1
Report this Post12-26-2016 09:19 PM Click Here to See the Profile for Atlanta1Send a Private Message to Atlanta1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any electrical gurus out there know about the wiring for the fiero volt and oil pressure gauge on the dash?
there are five wires that are tied into a plug.
