I also run lower strut spacers . I made mine around 1990. I have many hard, fast (Street) miles on them.
The single most important thing you must do is keep the strut at the same angel as stock. This angel sets camber curve. Some adjustment may be needed to this angle to tune for things like lowering and every thing you change that's related to rear suspension.
Remember that the rears don't steer so there is no “king pin angle”.
Moving the bottom of the strut in 2” means you should move the top in 2” also. Or use 2” longer “A”arm/ lateral links and axles.
Or rims with less back spacing, cheaper but not as good of fix. I think the best way to go is to move in as well as out to keep bearing lodes similar.
On my 85GT/IMSA I could not go that far in, and clear the strut tower. So made some spacers to move in the max I felt safe at, then moved the top in 1/4” more than the bottom to help comp for the angel of the “A”arms.
I use a 17x12 rim W 315R17-35 tires.
https://www.fiero.nl/forum/Forum1/HTML/096777.html https://www.youtube.com/cha...oJ3CMtWvgEok8R-n3XRg------------------
Sincerely
George
[This message has been edited by fierogt4e (edited 11-02-2016).]
