  F40 transmission gear ratios.
F40 transmission gear ratios. by Daryl M
Started on: 10-02-2016 03:44 PM
Replies: 7 (1038 views)
Last post by: Joseph Upson on 10-04-2016 07:31 PM
Daryl M
Report this Post10-02-2016 03:44 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
F40 transmission gear ratios are not all the same. For example, the Saab version has two different ratio combinations. The 2006, like I just bought, is geared higher (higher speed) while the 2007 and later are geared lower. Providing the hp is sufficient, a car tha has the 2006 transmission could go 210 mph @6000rpm, while a car with the 2007 and later would go 170 mph or so. The later transmission also has a much lower 1st gear and lower differential ratio. Something to keep in mind if one is considering an F40.
dobey
Total ratings: 371
Report this Post10-02-2016 04:01 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, there are at least two versions of the F40 in terms of gear ratios. I think one of the Saab AWD versions might have also had a 3.92 final, IIRC. The two most common, which you're referring to here, are both discussed on the Wikipedia page: https://en.wikipedia.org/wiki/GM_F40_transmission
Joseph Upson
Total ratings: 88
Report this Post10-02-2016 06:34 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
06 is the troubled transmission, 07 is the year with upgrades to address some of the problems faced in the 06 and it has at least two gear ratio changes in addition to the different final drive.
Daryl M
Report this Post10-03-2016 11:57 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Joseph, please elaborate on the problems with the 2006 F40.
dobey
Total ratings: 371
Report this Post10-04-2016 10:57 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many complaints about "rattling" with the earlier F40, and sometimes hard to shift.
Daryl M
Report this Post10-04-2016 05:47 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any info on the cause or a fix?
dobey
Total ratings: 371
Report this Post10-04-2016 07:20 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Read the wikipedia page. Using certain lubricants can help with the rattling, and the OE dual mass flywheel helps. People with solid aluminum aftermarket flywheels tend to hear the rattling more so. Sprung hub clutch should also help with the vibrations. The "fix" that GM performed was in the 07+ versions. I don't know that the changes can be retrofitted.
Joseph Upson
Total ratings: 88
Report this Post10-04-2016 07:31 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
There were a number of changes made apparently as a result of the number of complaints from G6 GTP owners. Some transmissions were replaced under warranty according to member complaints I read on the G6 forum. There was also a more descriptive listing on the GM Powertrain page around that time of all of the improvements. That page is archived now and probably no longer available. The rattle is one complaint that varied however, many had some difficulty with shifting into gear 1-2 on a cold transmission, something that I've experienced consistently. Aside from that the transmission worked fine. The rattle can be improved upon, or aggravated with idle rpm. The lower the engine idle, the more it tends to rattle. The choice of flywheel will also have an effect on that also. Around 900 rpm I don't hear any noise until I shut the engine off. One of the fixes to the shifting difficulty was a change to the recommended fluid level to lower from what I recall. Put the correct fluid in it, GM synchromesh is the wrong answer.
[This message has been edited by Joseph Upson (edited 10-04-2016).]
