  84 Muncie Identification??
84 Muncie Identification?? by boysatt
Started on: 10-02-2016 11:47 AM
Replies: 1 (271 views)
Last post by: pmbrunelle on 10-02-2016 02:09 PM
boysatt
Report this Post10-02-2016 11:47 AM Click Here to See the Profile for boysattSend a Private Message to boysattEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm parting out a bunch of fiero's and I pulled a 4 speed muncie out of a 86 GT V6 car. I can tell its a 84 transmission because the 84s had a different case but not sure if its a my8 or a m19. Any way to easily identify?
The case is cast 14066447 GM CFM-7
and has a sticker that says 614DW M
Thanks, Mike
pmbrunelle
Total ratings: 63
Report this Post10-02-2016 02:09 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used a wood stick as a transmission ID tool.
I inserted a piece of cedar shim into the differential carrier (tight fit). I then carved some clearance into the wood stick so it wouldn't rub on the axle seal.
Then, shift the trans into various gears and count the input : output turns. The wood stick just serves as a visual indicator.
[This message has been edited by pmbrunelle (edited 10-02-2016).]
