  Danger in too much Oil Pressure ?
Danger in too much Oil Pressure ? by Lou6t4gto
Started on: 09-03-2016 02:22 PM
Replies: 15 (607 views)
Last post by: Joseph Upson on 09-04-2016 07:34 AM
Lou6t4gto
Report this Post09-03-2016 02:22 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
NEW 2.5 . when it was" assembled", we "shimmed" the oil pump relief spring (about the thickness of a penny). engine runs Perfect, but it idles at about 40 PSI and when revved will actually PEG Both the dash Gauge And the new Mechanical Gauge, so it is really pushing about 100 when revved ! ( I know, 10 PSI per 1000 RPM) will this blow oil filter gaskets, break oil pump Drive shafts ect ?? thinking maybe I need to remove the shim. LOL
MadProfessor8138
Report this Post09-03-2016 02:37 PM Click Here to See the Profile for MadProfessor8138Send a Private Message to MadProfessor8138Edit/Delete MessageReply w/QuoteDirect Link to This Post
My concern would be focused towards pumping the oilpan dry.
Oil moved upwards mechanically with a pump moves faster than oil gravity feeding back down to the oilpan.
In the past,with a few engines that I've built,I've had to either use a pump with less volume or go with an oilpan that had more capacity due to pumping the oil to the top of the engine faster than it could drain back to the pan and then I would momentarily lose oil pressure due to the oil pump starving briefly.
Lou6t4gto
Report this Post09-03-2016 03:23 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmmm, Hadn't thought of that. it's a Stock replacement pump, not high volume, but I'll keep a watch on that at higher rpms (well, 4000 at the most) bone stock 1987 2.5 so definitely Not a Race car.
jaskispyder
Total ratings: 205
Report this Post09-03-2016 03:35 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could you have a clogged passage causing higher pressure?
tebailey
Report this Post09-03-2016 03:38 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could also pose a problem blowing seals.
viperine
Report this Post09-03-2016 03:55 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is this a fresh build? If you're still on the fresh break-in oil, it will read high. The first oil change with the correct oil will see lower numbers. Break-in oil is super thick compared to 5 or 10w30.
Joseph Upson
Total ratings: 88
Report this Post09-03-2016 03:55 PM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
It depends on why the oil pressure is high, because of the pump, bearing clearances or a combination of both. Tight clearances increase the risk of bearing damage due to reduced oil flow over them when the load is high but will register the seemingly adequate pressure at the gauge. I doubt you'll blow the filter or seal if it's solely the result of the pump mod as long as it's of good quality and installed properly and as for pumping all the oil up top that's usually the result of a high volume pump with a stock pan and it would show intermittently in the pressure gauge once the oil level in the pan dropped below the pump screen. I'd be more concerned about the mechanical stresses from the timing chain, to the cam and distributor gears and the shaft to the pump as has been pointed out.
To give you an idea of what the load is like, I nearly sprained my wrist priming a V8 with a drill once the oil was picked up and pressurized and on a 3.4L that I plugged the oil bypass passage in and installed spring shims on without checking for coil bind and ended ruining the cam, the engine was slowly dragged down to a stall after the oil filter clogged with metal shavings after I poured flush in the motor to wash the metal down to the pan before tear down.
100 psi shouldn't be the end of the world since 80 was common for the 2.8 new. If you don't know where you are above that I'd be concerned about the potential for a mechanical failure from the stress on the other stock parts.
2.5L Disregard, all that doesn't apply. With a 40 psi idle I doubt you're in any real trouble. I was thinking it was 100 at slightly above idle.
[This message has been edited by Joseph Upson (edited 09-03-2016).]
dobey
Total ratings: 371
Report this Post09-03-2016 04:07 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Break-in oil would probably be 30w, with extra ZDDP on an engine going into a street car, and so 5w30 or 10w30, or even 0w30, would all be the same as 30w at operating temperature. The 30w break-in oil would only be thicker at the lower temperatures prior to the engine warming up.
Lou6t4gto
Report this Post09-03-2016 04:43 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes, it's 30w break in oil with a can of STP (for the zinc). although I don't know it needs it with the roller cam. was thinking to Wait till it changed to 5-30 synthetic after break in and see what it is then. I see where the stress on the Cam gear might be a concern. It is surprising how much it takes to spin the oil pump ! Thanks
Total ratings: 154
Report this Post09-03-2016 06:58 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is this with a mechanical gauge? I wouldn't trust the electric gauge to be correct.
I think a properly tightened filter would hold 100 psi. I would be more concerned with the cam thrust plate seal, especially if it was original.
Ventura
Report this Post09-03-2016 07:11 PM Click Here to See the Profile for VenturaSend a Private Message to VenturaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I rebuilt my 2.5 using a Melling high volume oil pump. Every time I rev the engine past 4500 rpms, it blows out the oil pressure sending unit and dumps oil. This has happened at least six times now. I've tried different brands of sending units but to no avail. I have to carry a spare sending unit and oil just in case.
Lou6t4gto
Report this Post09-03-2016 07:21 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
got a feeling I may drop the pan and remove the "Shim". LOL
Total ratings: 328
Report this Post09-03-2016 09:41 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
With very high oil pressure I would be concerned with blowing an oil seal.
Ventura
Report this Post09-03-2016 09:54 PM Click Here to See the Profile for VenturaSend a Private Message to VenturaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Which oil seal? The oil pressure sending unit and valve float are the biggest problems with excessive oil pressure on the 2.5.
Ventura
Report this Post09-03-2016 10:07 PM Click Here to See the Profile for VenturaSend a Private Message to VenturaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ventura
Member since Mar 2011
Too much oil pressure can also cause valve float. Hydraulic lifters can pump up and lose lash. Its like a mechanical rev limiter on higher rpm engines. High volume/high pressure pumps are ok on v6 and v8 engines due to more places for oil to escape. I will only use stock oil pumps on 4 cylinder engines from now on.
Joseph Upson
Total ratings: 88
Report this Post09-04-2016 07:34 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not too sure about the valve float theory as the lifters don't so much pump up as they do fill with a small quantity of oil to bleed off and through while running, not to mention if it were possible, the oil pressure would have to exceed the total opposing pressure produced by the valve spring assembly which is far in excess of 100 lbs because the rocker is offset toward the spring side meaning the resistance produced by the spring would need to be multiplied by the rocker arm ratio producing upwards of 150 lbs or more. Also the amount of plunge travel to the lifter top remaining after lash is set properly isn't enough to allow this to happen. If you over tighten during the rocker adjustment yes but I don't see it happening otherwise.
