Hi guys!
I have a GT with the automatic transmission with the lines going to the front and connected to the radiator. I am installing a new radiator, but am wondering if there is anything I need to worry with when disconnecting the lines from the old transmission and reconnecting to the new one... Obviously the new one will not have any fluid in it and I am sure air will get in through the line connections.. Is there anything I need to do once the connections are made there?// Purge lines somehow? I am hoping you guys will be able to give me some feedback here. I am changing my single core radiator for the three core radiator to help with the cooling needs, so it is not leaking or anything like that. It has air-conditioning, but that is a completely different condenser coil in front of the radiator. I know that I will need to do some burping of the cooling system as well, so any advice on this would be appreciated as well.
Here is new 3 core aluminum radiator to install
new radiator with frame on top as a test fit
Old single core stock radiator
Top view of old radiator
I am checking on the lineup of the transmission lines and that they are in the right places, but look OK so far. I have new radiator hoses to install because I do not know how old these are in the pictures.
I am a little worried about getting air in the lines and is why I am asking if any of you guys have swapped an automatic transmission radiator before for advice and if there is any secret things I need to watch for here.
thanks in advance!
mrstan
Stan
1988 Fiero GT.. All stock.. sorry.
