  Leak in 4T65E-HD
Leak in 4T65E-HD by TXGOOD
Started on: 07-08-2016 09:30 PM
Replies: 13 (849 views)
Last post by: TXGOOD on 11-14-2016 04:39 PM
TXGOOD
Total ratings: 87
Report this Post07-08-2016 09:30 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is tranny fluid slowly leaking from this hole.
That`s up on jackstands with the car off.
Now, I would imagine that it`s leaking more when in gear or going down the highway.
There was a bunch of tiny tranny drops all over the back of the car.
I`m sure it`s leaking from there because I wiped it off and watched as fluid formed around the lip from inside of the hole.
I would imagine that hole is for maybe a mount to be threaded in from another application.
The hole is blocked but there is a slight void in one side of it.
I`m tempted to either get a rubber stopper or use maybe jb weld.
Any thoughts?
Thanks
[This message has been edited by TXGOOD (edited 07-08-2016).]
tebailey
Report this Post07-08-2016 09:42 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
A leak there is usually a torque converter seal.
TXGOOD
Total ratings: 87
Report this Post07-08-2016 09:48 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you talking about the large seal that the torque convertor goes through or the small seal on the shaft for the lock-up.
I had the transmission out not long ago and I replaced that seal.
I pulled off the inspection plate and the torque convertor and the bell housing seems dry inside.
tebailey
Report this Post07-08-2016 10:24 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the inside of the bellhousing is dry then it may not be the convertor seal.
tebailey
Report this Post07-08-2016 10:26 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
tebailey
Member since Jan 2013
You can try to put a plug in there and see if it stops the leak.
TXGOOD
Total ratings: 87
Report this Post07-08-2016 10:26 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just went and looked at another 4t65e that I have and what`s strange is it has a hole just like mine in the car and when I looked inside of it the bottom has what appears to be a bit of lead or something right at the bottom on one side. If that little drop of lead weren`t there it would have a hole just like the one in my car. I think something must have fallen out of that small hole in the bottom of the opening, although I can`t imagine what it`s purpose could be.
TXGOOD
Total ratings: 87
Report this Post07-08-2016 10:29 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
TXGOOD
Member since Feb 2006
That`s what I`m going to do.
I don`t imagine it can hurt anything.
Thanks
I`m just curious if there were a number or a certain year that they bored that hole a little deep and it broke into a channel or something and the cure was to just stick some kind of sealing compound in there to seal it up.
tebailey
Report this Post07-08-2016 10:37 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
Could be, I've seen stranger things.
TXGOOD
Total ratings: 87
Report this Post07-09-2016 10:40 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, the hole was not the problem.
I drove my car across town and by the time I got there the back of my car had transmission fluid all over it.
I got under it and there was oil coming out from around the inspection plate.
I don`t see how it`s leaking from the seal where the torque convertor goes into the transmission because I replace that seal not long ago.
Oh well, I guess it`s coming out.
[This message has been edited by TXGOOD (edited 07-09-2016).]
TXGOOD
Total ratings: 87
Report this Post11-13-2016 09:29 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
Car is going again.
I ended up getting a new heavy duty flex plate from ZZP because mine was warped.
Also a new torque converter because the bushing was worn.
When I pulled the transmission from the engine the torque converter seal was almost out, thus the leak.
I assume the warped flex plate caused the seal to back out.
I replaced the seal and resealed the oil pan gasket because I think it had a leak as well.
So far no leaks under car.
Dang, I didn`t realize my car was down for 4 months.
[This message has been edited by TXGOOD (edited 11-13-2016).]
Lou6t4gto
Report this Post11-14-2016 12:19 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can not "view" your Picture. a 4t65e has a torque conv seal
side cover gasket
pan gasket
2 axle seals
you ruled out the tc seal, so......
wish I could SEE the picture of the hole you speak of.
TXGOOD
Total ratings: 87
Report this Post11-14-2016 09:05 AM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
side cover gasket
pan gasket
2 axle seals
I replaced the torque converter seal.
Lou6t4gto
Report this Post11-14-2016 01:52 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
If both the "bushing" and the "TC" were shot, did you at least change the fluid and the filter ??
TXGOOD
Total ratings: 87
Report this Post11-14-2016 04:39 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh yea, I replaced the flat pan on my existing transmission with the ZZP finned pan that I had laying around.
I replaced the filter and the fluid.
Actually the bushing wasn`t that bad it had just worn unevenly on one side.
The flex plate was terribly warped, although I`m not sure how it got that bad.
