  Use sealant on rubber oil pan gasket (87 2.8)?
Use sealant on rubber oil pan gasket (87 2.8)? by Dwayne
Started on: 07-08-2016 07:40 AM
Replies: 7 (309 views)
Last post by: 2.5 on 07-08-2016 03:12 PM
Dwayne
Report this Post07-08-2016 07:40 AM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Should I use some Permatex gasket sealant on rubber oil pan gasket (87 2.8)? Don't want have to do it a second time.
Thanks
Total ratings: 207
Report this Post07-08-2016 09:37 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
What does the manufacturer's literature instruct?
Dwayne
Report this Post07-08-2016 09:56 AM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
3mm (1/8") bead of GM 1052917 RTV sealant or equivalent. Has anybody used rubber instead?
Report this Post07-08-2016 11:29 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Id put a skin of sealant on, just rub the gasket with fingers so there is some on both sides. Then install but only tighten to snug at first or even that small amount will ooze out some. After the sealer sets, then torque to spec. I use Permatex black or orange.
Dwayne
Report this Post07-08-2016 02:15 PM Click Here to See the Profile for DwayneSend a Private Message to DwayneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Black or orange would be RTV I believe. I was going to use Permatex High Tack Gasket Sealant. it gets very tacky quick. Fel-Pro Molded rubber gaskets state to install dry. would like to do a thin skin of sealant...I guess ill do the dry install and cross fingers
88cryan
Report this Post07-08-2016 02:32 PM Click Here to See the Profile for 88cryanSend a Private Message to 88cryanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Install dry with dabs of rtv around any seams in the block....ex: where front cover meets block, rear main cap, etc
thesameguy
Report this Post07-08-2016 02:54 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, if this is a Felpro dry seal gasket, you don't need anything and shouldn't use anything. A dab at seams in the block/covers make sense, but nothing more. I have never had a permadry (I assume that's what you've got) leak.
Report this Post07-08-2016 03:12 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
For sure of its permadry, blue with the ribs on it don't use any sealer.
