  Shift vs. Selector cable?
Shift vs. Selector cable? by I_N_J
Started on: 06-19-2016 12:22 PM
Replies: 4 (1087 views)
Last post by: Patrick on 06-19-2016 02:16 PM
I_N_J
Report this Post06-19-2016 12:22 PM Click Here to See the Profile for I_N_JSend a Private Message to I_N_JEdit/Delete MessageReply w/QuoteDirect Link to This Post
Driving home today, one of my transmission cables went out, leaving the car stuck in 3rd gear... so that was fun. Anyways, upon arriving home, I found the problem to be a break in the cable that is moved with forward-backward movement of the stick. Looking online, I can find shift and selector cables. Which cable is which?
It's a 1985 Fiero 4 cyl with an Isuzu 5 speed.
Total ratings: 461
Report this Post06-19-2016 12:29 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shift cable - front to back
Select cable - side to side.
tebailey
Report this Post06-19-2016 12:41 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
If your tearing into it to replace one, I'd replace both. One has already broke how long will the other one last?
I_N_J
Report this Post06-19-2016 02:10 PM Click Here to See the Profile for I_N_JSend a Private Message to I_N_JEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, I probably should do that. It'd probably help the slop I have in the shifter as well.
Thanks for the help guys, I appreciate it.
Total ratings: 461
Report this Post06-19-2016 02:16 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Although in the case of the Getrag, the tranny end of the select cable basically points straight up... which is ever so inviting for water to enter and allow corrosion to take place. On the other hand, the shift cable is positioned quite differently and should far outlast the select cable.
