  Air conditioning diode / resistor
Air conditioning diode / resistor by Mar21457
Started on: 06-18-2016 11:58 PM
Replies: 3 (186 views)
Last post by: Mar21457 on 06-19-2016 01:25 PM
Mar21457
Report this Post06-18-2016 11:58 PM Click Here to See the Profile for Mar21457Send a Private Message to Mar21457Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm getting ready to charge my my AC and I noticed a wire , diode or resistor on the two wire connector, on the compressor and It was broken in half, can anyone tell me what this does without looking it up in my service manual .
[This message has been edited by Mar21457 (edited 06-19-2016).]
Joseph Upson
Total ratings: 88
Report this Post06-19-2016 06:13 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a diode and prevents reverse current flow back to the source when the compressor is turned off a process that works similar to the way the igntion coil does but without producing as much voltage. Since there is no secondary winding in the relay the current tries to go back to the source when the magnetic field is dropped but is stopped by the diode. The diode protects electronic devices in this case from stray current interference.
[This message has been edited by Joseph Upson (edited 06-19-2016).]
Report this Post06-19-2016 08:50 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Common problem. Yes, surge suppression so coil can't put 700v or more to the car when relay turns off. (Most relays have diode on their coils too.)
Rock auto and many others have new plugs w/ diodes.
Mar21457
Report this Post06-19-2016 01:25 PM Click Here to See the Profile for Mar21457Send a Private Message to Mar21457Edit/Delete MessageReply w/QuoteDirect Link to This Post
Picked up a new connector with pigtail and diode, thanks guys!
