  4 speed transmission swap
4 speed transmission swap by jaybug56
Started on: 06-17-2016 01:16 PM
Replies: 4 (219 views)
Last post by: fierofool on 06-20-2016 08:09 PM
jaybug56
Report this Post06-17-2016 01:16 PM Click Here to See the Profile for jaybug56Send a Private Message to jaybug56Edit/Delete MessageReply w/QuoteDirect Link to This Post
My trans in my 86 finally gave up the fight. Got locked in 3 - 4 only. I have a 4 speed from a 84 (smooth case and the FWD cable brackets). I know that the trans will fit but can I simply swap all the brackets from the 86 trans to the 84 trans including the slave cylinder and bracket. I noticed that there is a separate slave for 84s listed on TFS
[This message has been edited by jaybug56 (edited 06-17-2016).]
Report this Post06-19-2016 10:04 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Report this Post06-20-2016 09:25 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can just swap out the transmission if your 86 is a 4-speed. The reason for the different 84 slave was because they just used a different mount. Everything you have on the 86 will work on the 84 trans.
jaybug56
Report this Post06-20-2016 07:58 PM Click Here to See the Profile for jaybug56Send a Private Message to jaybug56Edit/Delete MessageReply w/QuoteDirect Link to This Post
All right. I'm going in.
I will swap all brackets and use the '86 slave
I noticed that the arm is different also but it should not matter.
Thanks for the advice
[This message has been edited by jaybug56 (edited 06-22-2016).]
Report this Post06-20-2016 08:09 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You do know your 84 trans is probably a 4:10 ratio? It will be quick on acceleration but will be running some high rpm's at road speed. Probably in the neighborhood of 3500 rpm. MPG will be much less than with the old trans but it's sure fun to drive on twisty roads and getting away at green lights.
