  Engine Damper Shock -> Worth Replacing?
Engine Damper Shock -> Worth Replacing? by bortolini
Started on: 06-14-2016 01:03 PM
Replies: 14 (1140 views)
Last post by: theogre on 09-13-2016 09:56 AM
bortolini
Report this Post06-14-2016 01:03 PM Click Here to See the Profile for bortoliniSend a Private Message to bortoliniEdit/Delete MessageReply w/QuoteDirect Link to This Post
like the subject says, is it worth it to replace the engine damper shock? I am purchasing parts for my engine rebuild (heads & block at machine shop currently) and am curious if this is really seen as something that should be replaced or not worth the $... Thanks.
jaskispyder
Total ratings: 205
Report this Post06-14-2016 01:36 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
GM thought it was worth the money....
thesameguy
Report this Post06-14-2016 01:52 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not entirely sure what GM thought was a good idea in the '80s is indicative of the actual value of a thing in 2016.
Blacktree
Total ratings: 350
Report this Post06-14-2016 02:00 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
... then deleted it for the '88 model year.
People often mistake the shock absorber for an engine mount. It doesn't actually help to hold up the engine, or hold it in place. It's there to dampen vibration. It must have something to do with the pre-'88 engine cradle or lower engine mount design, because the '88 Fieros don't have it.
So, do you need that shock absorber thingy? I can't definitively answer that question. But I ran my V6 without it for several years with no ill effect. Then I swapped in an '88 engine cradle, which doesn't use it.
[This message has been edited by Blacktree (edited 06-14-2016).]
jaskispyder
Total ratings: 205
Report this Post06-15-2016 07:30 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
'88 V6 had internally balanced engine.
https://www.fiero.nl/forum/A...120111-2-110752.html
'88 also used a solid mount subframe.
'88 has a different engine mount bracket.
BTW, I have heard of these being called Torque Dampers...
[This message has been edited by jaskispyder (edited 06-15-2016).]
jaskispyder
Total ratings: 205
Report this Post06-15-2016 07:36 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
jaskispyder
Member since Jun 2002
I would agree, IF during the removal, a better solution was used to make up for the loss. Removing an engine damper and not making accommodations for the loss doesn't mean things are better because it is 2016. Just saying.
Is it necessary? No. Does it do something (when new)? Yes. Again, why would GM ENGINEERS put this in place if it wasn't necessary? Maybe it was an inside joke or maybe they had a bunch of shocks to get rid of, but I doubt it.
pmbrunelle
Total ratings: 63
Report this Post09-12-2016 12:29 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rarely are things "strictly necessary". The damper is there because someone at GM thought the car would be "more optimal" with the damper, according to their judgement.
If we re-evaluate things with our own criteria, who's to say that you would make the same judgement call as the original design team? It's arbitrary.
Here's my speculation:
Probably while dumping the clutch, someone thought that the rubber mounts/dogbone allowed "too much" engine movement. Again, what constitutes "too much" movement is subjective. How much clunk noise is acceptable? Subjective. How much should fuel/coolant lines be allowed to flex on such a maneuver? Kind of open for discussion.
On a clutch dump, the damper would become rigid and hold the engine in its place. The rest of the time, the damper does nothing, and it's rather the rubber-bushed dogbone holding the engine. So the damper solution would allow for the good NVH characteristics of rubber most of the time, but a more rigid mounting than rubber under hard shifts/launch.
tesmith66
Total ratings: 135
Report this Post09-12-2016 12:43 PM Click Here to See the Profile for tesmith66Send a Private Message to tesmith66Edit/Delete MessageReply w/QuoteDirect Link to This Post
GM put it there because they screwed up the motor mounts so bad. Why do they always mount transverse drive trains with sooo much movement? To sell more mounts?
I put my DOHC in with 4 rubber mounts, no dogbone, no shock, no excessive movement and no problems.
This, of course, my opinion. If GM did everything right, we wouldn't be here modifying everything.
1986 SE Aero coupe.
jaskispyder
Total ratings: 205
Report this Post09-12-2016 01:09 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it wasn't seen as necessary (engineers, mind you), then it wouldn't be there. Bean counters would have nixed it.
viperine
Report this Post09-12-2016 01:48 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck finding a replacement, anyway! To eliminate it, I would consider upgrading at least some of the rest of the mounts with poly mounts. Especially the upper dogbone. This may help compensate for removal of that damper.
jaskispyder
Total ratings: 205
Report this Post09-12-2016 01:51 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
http://rodneydickman.com/ca...h=22&products_id=348
viperine
Report this Post09-12-2016 11:07 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suck at navigating Rodney's site. Always takes me 15 minutes to find what I'm looking for haha
jaskispyder
Total ratings: 205
Report this Post09-13-2016 06:33 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Google.....
Total ratings: 154
Report this Post09-13-2016 09:02 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Didn't they also change the front mount in 88? I can tell you that having hit the twisties hard every year in Run For The Hills, with a lot of up and down shifting, I could feel the engine shifting when my engine shock absorber went bad on one car, and when the mount broke on another. It isn't as noticeable in regular highway driving until other mounts and bushings start to wear, but when doing hard acceleration and deceleration, you can feel it.
Report this Post09-13-2016 09:56 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many mounts go bad when engine/trans are push to limits. Even new mounts can tear apart and Not just Fiero setup but Most of them for inline RWD setups too.
Common is to mount cable/chain across the Left (RWD) or Front (FWD/Fiero) mounts to stop tearing them. Cable/chain is installed just loose enough to let engine move for normal driving.
Some Aftermarket and OE Mounts are made to resist this force. Some designs you easily see this, others hide the feature.
"Shock" and dogbone are design to limit mount tearing forces too.
Later versions of "OE" bones are crap.
See my Cave, Torque Strut at bottom.
