  Ac compressor removal
Ac compressor removal by painandgain99
Started on: 06-12-2016 05:14 PM
Replies: 9 (2122 views)
Last post by: cmechmann on 06-14-2016 11:08 PM
painandgain99
Report this Post06-12-2016 05:14 PM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
I decided f*** it im going to give changing the clutch a go. Having troube getting the ac compressor out, i got the out bolt loose and realized theres a nut on the other side but i cant for the life of my get a wrench on it, no room. Any tips?
87' GT 5 speed 😤 16 years old
My IG for daily motivation: Alpha_Photos
88FieroGT TTops
Report this Post06-12-2016 05:34 PM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
S shaped box wrench--you can get them at harbor freight. the service manual for my car shows nut on outside of bracket though--have you discharged the system and remove those hoses yet? have you disconnected the electrics? get those out of your way will make it easier
Pat Jones
painandgain99
Report this Post06-12-2016 06:38 PM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you. Im going to pick back up tomorrow. If i read correctly, i can discharge the frion (by a mechanic) and just disconnect the hoses and leave the compressor attached?
Also i dont see the transmission cooler liner or the heater core return line. The thread im reading to remove the engine i dojt recognize where they sre at from the photos
notwohorns
Report this Post06-12-2016 09:46 PM Click Here to See the Profile for notwohornsSend a Private Message to notwohornsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, just disconnect the hoses from the compressor and leave the hoses hanging (after the Freon has been removed). The transmission cooler lines are on the driver's side on the inside of the frame rail behind the tire. All the hoses that need to be removed, I just disconnect them from the engine
tnkgnr
Report this Post06-12-2016 11:17 PM Click Here to See the Profile for tnkgnrSend a Private Message to tnkgnrEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used a ratcheting wrench on that right one (as you are under the car, facing it from the firewall). After I got the right one off, it was slightly easier to get to the left - I used a socket with swivel and and extension... it's of course a tight fit and had to be readjusted several times, but I eventually got it off. I of course disconnected the hoses from the compressor first to give some extra room to work.
painandgain99
Report this Post06-13-2016 01:46 PM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks you guys very helpful answers. Yesterday i started moving on to other steps (but not too many steps ahead) from the ac compressor caus ei couldnt get it. I started trying to break one of the resr cradle bolts and its a pita. I got it to move slightly, i assume low and slow is the way for these without breaking the bolt off. I keep hitting them eith pb blaster.
One more question. Im doing this on gravel in my driveway as i had no other choice. Its flat and the jackstands and chucks arent going anywhere. But i already see there will be an issue moving the engine dolly. At this point i have a few options. I can try it on the gravel and just dig deeper into the job of removing it, i can pull the car to my mechanic 2 blocks away. Or i can use someones garage but if i did i wouldnt have much time. 85% of the work for eemoving and installing i can do without really getting caught up on anything. But im afraid once i drop the cradle i wont be able to get it to line back up when i go to put it back in. How difficult is this? And once the engine is out is the clutch time consuming to change? I was thinking to just lift the car high enough to be able to reach the tranny and then put it on stands with a 4x4. I just dont want to get stuck on a part and have to haul everything to the mechanic on a trailer 😂
88FieroGT TTops
Report this Post06-13-2016 03:36 PM Click Here to See the Profile for 88FieroGT TTopsSend a Private Message to 88FieroGT TTopsEdit/Delete MessageReply w/QuoteDirect Link to This Post
maybe a big flat piece of plywood---provides a smoother surface
Pat Jones
painandgain99
Report this Post06-14-2016 01:21 AM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
Going to pull the car to a friends house tomorrow. Im planning on getting the cradle out tomorrow. Just curious as to what i do once i drop the cradle assembly. The actual clutch part of the job. Im not understanding how to pop out the axles. Is there any detailed page on the forum on what to do to change the clutch once the engine is out? Ive been looking but cant find anything
painandgain99
Report this Post06-14-2016 09:56 PM Click Here to See the Profile for painandgain99Send a Private Message to painandgain99Edit/Delete MessageReply w/QuoteDirect Link to This Post
painandgain99
Member since Jul 2015
Bump
cmechmann
Report this Post06-14-2016 11:08 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think you are going about this the hard way. Your changing a standard transmission clutch?.
You don't have to completely remove the engine. You do however need to drop the rear of the cradle down enough that the transmission clears the frame rails.
From the top. Disconnect the radiator hoses, after draining the coolant. The wiring harness on the engine should be long enough to leave alone. Disconnect the dogbone/torque strut. On 87s and 88s the heater return hose is part of the right radiator hose. V6 85 and 86s the hose goes to a tube off the water pump. The other hose you remove later. I suggest removing the positive and negative battery cables and look for any ground straps that may interfere with lowering the rear of the cradle.
Block the front wheels. Carefully with jack stands (or the 4x4 setup)support the car at the jacking points. The jacking points are heavy metal brackets that cover the coolant tubes about 8 inches in front of the rear wheel openings. BEING CAREFUL NOT TO DAMAGE THE COOLANT TUBES.
With the A$$ end up. With the parking brake on. Remove the rear wheels. Remove the large axle nuts. Remove the pinch bolts on the rear lower ball joints. Loosen the front subframe/cradle bolts. Just loosen about 1/2 turn. You see why later. Leave the compressor alone. Do not remove the A/C hoses. Do not remove the front engine mount. Drain the gear oil out of the transmission. At this point you want to push the control arms down off the spindle then try to pop the axles out. The best way I have found is with a pry bar between the inner CV joint and the transmission case. Not on the seals. In a quick motion pop the axles free from the transmission and get them out of your way.
Remove any bolts from under the engine. Flywheel cover and lower engine to transmission bolts. You can remove the starter, but really isn't needed.
Remove the slave cylinder. But leave the hoses and lines connected to the slave cylinder. If there are brackets holding the lines to the transmission, remove them too. Remove the shift cables.
With the rear of the cradle supported with a jack. Remove the rear cradle bolts. Remove any exhaust springs or after market hangers that attach to the body of the car. The ones that attach to the cradle can be left alone.
Lower the rear of the cradle about 4 inches. Do not lower the front. You should now be able to reach the other heater hose easier and look for any part of the harness that may be getting tight. If you have to disconnect the harness and alternator cables at the bulk connector near the battery. If all looks clear, lower the rear of the cradle about another 6 inches. There should be a clear view of the transmission from the driver's side of the car now. To make things a little easier, remove the left caliper. Remove the left outer tie rod and remove the left strut. If it looks like enough room to remove the trans out the left side now, support the rear of the cradle with wood blocks. You should notice with the car up and the rear of the cradle down, the cradle is somewhat level. Take the jack you removed from the cradle and put it under the oil pan close to the flywheel end with a piece of wood to protect the oil pan. Raise the jack just enough to take the weight. Now you should be able to remove the transmission mounts. You may have to move the jack some to make sure the engine is stable. All you should have left holding the transmission, is the upper engine to trans bolts. They should be easy to get to now also. Remove them. The transmissions do tend to "stick" on the dowel pins and you may have to wiggle it around to free it from the engine. But you should be able to remove it from the left side of the car. After removing, inspect and clean the input shaft and clutch release hardware. Remove the 6 bolts holding the pressure plate to the flywheel. Inspect the flywheel. There are most likely going to be hot spots and I highly suggest you have it machined.
Your clutch kit should have an alignment tool to align the clutch disc, when installing, use it. Find two bolts about 2 inches longer then the trans to engine bolts with the same threads and cut the heads off. Install these in 2 easy to get to places on the engine. Those will assist you in aligning the transmission back up when you install it and help keep it from binding on the input shaft. When you get the trans back on, install 1 of the regular bolts and remove the cutoffs. The rest should be reverse of removal.
The Idea of this is to leave the engine in place on the cradle.
[This message has been edited by cmechmann (edited 06-14-2016).]
