  Cigarette lighter always powered? Battery drain?
Cigarette lighter always powered? Battery drain? by FStorm
Started on: 06-05-2016 02:34 PM
Replies: 4 (563 views)
Last post by: MulletproofMonk on 06-14-2016 10:20 AM
FStorm
Report this Post06-05-2016 02:34 PM Click Here to See the Profile for FStormSend a Private Message to FStormEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replaced the cigarette lighter today with a set of USBs led is always lit, even when the ignition is off/no keys.
1. Is the cigarette circuit always powered? 2. Will the led cause noticeable battery drain?
This images is larger than 153600 bytes. Click to view. Old lighter, Back in Black playing on Millennium Falcon, coffee, what else do you need?
Center console out
Rear console out, testing new USB ports. Works fine to charge my Samsung Galaxy Note 5
Better view of USBs installed in console
[This message has been edited by FStorm (edited 06-05-2016).]
cebix
Report this Post06-05-2016 04:43 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, it is always on. It's powered from the BAT fuse.
Report this Post06-05-2016 05:02 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
LED(s) isn't only issue. USB w/o anything in it can use power too.
If you drive every day may not drain battery too much.
Depending on battery, exact power used by ECM Radio and your new toy, Park for weekend or a week then you might have problems.
Best to use a source that's on w/ key in ACC and ON.
Fuse box have plugs that do just what is needed.
Ray_and_kevin
Report this Post06-07-2016 02:15 PM Click Here to See the Profile for Ray_and_kevinSend a Private Message to Ray_and_kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I frequently leave my USB charger with LEDs active plugged in to the cigarette lighter for days without the car running. It won't kill a good battery for maybe a week as Ogre said. Of course all the other stuff in the car *will* kill a battery in about a month depending on the shape of the battery, alternator, electronics. You will have the ECM, the radio, and perhaps a couple of other loads drawing a few milliamps 24/7. An old battery won't last a week in Texas heat.
MulletproofMonk
Total ratings: 78
Report this Post06-14-2016 10:20 AM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just wired a switch on mine. I turn the switch off and no power to the lighter socket...
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
