I tried searching for this, but when searching both AC and radiator fan, so much unrelated stuff comes up I just had to ask...
My '88 GT will run the radiator fan the entire time the key is turned on. Also, when the engine is running the AC clutch is always kicking on and off on the compressor. If I turn the HVAC controller to OFF it stops, but if I put it on ANY of the other settings the radiator fan and AC clutch both start doing their thing. I can only imagine it's related!
Is there a common issue of why your AC system would be triggered all the time the HVAC is activated?
As I understand it the ac clutch kicking on is an issue regarding the amount of charge or restriction in the system. Either low charge or a restriction in the flow. But I'm no expert.
So even if you have the blower set to floor, (not AC) it triggers the ac compressor and fan?
I have an 88 4cyl. So I can't be much help comparing A/C systems since they use different compressors. Here's my dropbox link for the 88SM, (and some other info). Should help some if you don't have one.
Many people don't realize that the A/C also runs in Defrost mode... but no, it shouldn't be running in Heater or Vent mode.
Patrick brings up a very good point here. When controls set to defrost it does cycle the AC, and as far as I understand, it does not run the radiator fan in defrost mode. Is that correct?
------------------ "Because in a split second, It's gone" Ayrton Senna
I removed the A/C from my Formula when I got it (so I can't go check)... but I believe anytime the A/C is running (including while in Defrost mode), the rad fan is running. I'm sure someone with their A/C still installed will easily be able to clarify this.
[This message has been edited by Patrick (edited 05-21-2016).]
Thanks folks. I have an '86 parts car, so I'm hoping the control unit in the dash is the same as my '88. I'll try swapping them out. If that doesn't do it I'll bring it to a shop that does AC work and get their input on if the system is too full or not full enough and go from there.
Uh-Oh, my AC is working and has been fine since it was fixed about 4 years ago. But my radiator fan does not run in defrost, it only runs when control is set to AC max, norm, and b/l. BTW, this is on my 86 GT. My others don't have working AC.
Not sure about the 88's. But on 1985-87 V6 models with AC, the radiator fan does NOT run with the defroster even though the AC is cycling. The radiator fan only operates on Max, Norm, or Bi-level.
A jumper wire can be added to the circuit board on an early HVAC head to enable the cooling fan to run in DEFROST mode. Sorry, can't post pics from my phone....
All years of heat/air controls function the same and will plug right in. 84 units have different color buttons, but they also work the same way.
------------------ Rod Schneider, Ball Ground, Ga. "You can't have too many toys!" 1988 Fiero GT 1988 Porsche 928S4 1987 Corvette 2001 Chrysler 300M Van's RV-6 airplane
