  Can just the starter solenoid be replaced on 3800 starter?
Can just the starter solenoid be replaced on 3800 starter? by doublec4
Started on: 05-02-2016 07:45 PM
Replies: 5 (217 views)
Last post by: 84fiero123 on 05-03-2016 02:01 PM
doublec4
Total ratings: 150
Report this Post05-02-2016 07:45 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was removing the wires on my L67 starter today and the small stud for the signal wire broke off. The solenoid portion of the starter looks to be in pretty rough shape since it was near the exhaust for a few years. Is it possible to just replace the solenoid without removing the large starter body?
Report this Post05-02-2016 08:26 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
It can be done, but most people find it easier to remove the entire starter, and as long as you have it off the car, replace it.
Should be about $60 - $75.....$US. Don't know what the exchange rate is doing these days.
[This message has been edited by Gall757 (edited 05-02-2016).]
doublec4
Total ratings: 150
Report this Post05-02-2016 08:56 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, I just found the solenoids on rockauto so it looks doable. I might just take mine apart and see if I can replace just the stud that broke.
84fiero123
Total ratings: 325
Report this Post05-03-2016 09:17 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have got to agree, working in those cramped spaces is a good way to hurt your hands. Pull the starter and the solenoid comes with it, and if you chose just to replace the solenoid do yourself a favor and have the starter tested before reinstalling, most parts stores now will do that for free. Be a real pain to have to take it back out because the starter goes after you replace just the solenoid a few weeks down the road. O'Reilly's does and give you the test results on paper so then you can decide if it is worth it.
Steve
[This message has been edited by 84fiero123 (edited 05-03-2016).]
doublec4
Total ratings: 150
Report this Post05-03-2016 01:07 PM Click Here to See the Profile for doublec4Send a Private Message to doublec4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the advice guys. You're right, the whole thing drops with two bolts so I'm going to remove it tonight.
84fiero123
Total ratings: 325
Report this Post05-03-2016 02:01 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Don't forget before doing anything else to disconnect the battery, then the wires going to the solenoid, then the mount bolts if you can in that order. If you don't you may short the battery out.
Steve
