  Why does my alternator light not come on?
Why does my alternator light not come on? by Kitskaboodle
Started on: 04-26-2016 12:37 AM
Replies: 5 (132 views)
Last post by: Blacktree on 04-26-2016 04:45 PM
Kitskaboodle
Report this Post04-26-2016 12:37 AM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi guys...this last Sunday I noticed my voltmeter gauge on my 85 GT started dipping to around 12 volts but the car drove ok. A little later the car started getting hard to start and then I noticed the gauge had dipped way down to 8-9 volts. Long story short, I got a jump from a stranger but the car simply didn't make it home. (it was obviously running off the battery only) Anyways, I charged the battery and got the car home. As a test, I turned the key to the On position and I noticed the center aux gauge voltmeter red light did come on. So, if the alternator is not working period, how come the light didn't come on?
P.S. As an FYI my 85 GT has the 86-88 GT center guage pkg. (I upgraded)
Maybe I wired something wrong?
Thanks, Kit
[This message has been edited by Kitskaboodle (edited 04-26-2016).]
Monkeyman
Total ratings: 182
Report this Post04-26-2016 01:25 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe it's something as simple as a burned out bulb?
Total ratings: 154
Report this Post04-26-2016 08:28 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the bulb is burned out, the alternator won't charge. It will eventually drain the battery.
85 SE VIN 9
Report this Post04-26-2016 12:04 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think he said it did come on. Isn't it the other one, the one on the dash, that you need for charging? It provides the resistance needed to "excite" the alternator and make it charge. In other words you may simply need the dash alternator light bulb. It should also come on with the ignition on, engine off.
On the pre-88's the alternator regulator plug is on the bottom. Maybe it fell out or became loose.
Report this Post04-26-2016 04:33 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The 85GT used the battery light in with the speedo and tach. Later years moved the volt light in with the auxiliary pod over the heater vents.
Blacktree
Total ratings: 350
Report this Post04-26-2016 04:45 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The alternator in my '87 SE went bad once... the battery warning light didn't come on until the battery was almost dead (engine started sputtering). That's not much of a warning.
