I was investigating something similar last week. I have a series 1 L67 that seized on me, and was having a hard time finding a replacement, so researched using a NA block. The main differences internally is the NA is a higher compression ratio, and the rods are not as strong as the L67 rods. That being said, it has been done a few times. The expectation was that it would hold up for a while, but eventually it might take out a rod.
I now have two '95 blocks I'm working with, and will have a spare set of rods ( and pistons) from a 92K motor, if you think you might want to go that far.
'87 GT in process, including GA / Seville brakes, Poly Suspension, '95 3800 Series 1 SC ( 225 hp ) 4t60e.
