  How to drill 12 inch corvette brake rotors 5x100
How to drill 12 inch corvette brake rotors 5x100 by j bf1
Started on: 04-07-2016 04:05 PM
Replies: 9 (1109 views)
Last post by: fieroguru on 04-08-2016 06:30 PM
j bf1
Report this Post04-07-2016 04:05 PM Click Here to See the Profile for j bf1Send a Private Message to j bf1Edit/Delete MessageReply w/QuoteDirect Link to This Post
If I remember correctly Fieroguru had it on the forum, but I can't find it. Please help. Thank you
~John
'88 GT 5spd White/Beechwood (modded)
'00 Corvette vert. 6spd Yellow/Black (lightly modded)
'05 Colorado Xtreme Black/Graphite
'13 CanAm Spyder ST-S SE5 Pearl Yellow (modded)
[This message has been edited by j bf1 (edited 04-07-2016).]
Fiero Vampire
Report this Post04-07-2016 05:39 PM Click Here to See the Profile for Fiero VampireSend a Private Message to Fiero VampireEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not sure if his thread has been archived or deleted, I just read it recently and now when I try to goto it, It says it's no longer exists. The best I could do for you is link you to a similar Google cached page of how to by Topcat, (wasn't able to find fieroguru's) Price check - drilling Vette Rotors to a 5x100
[This message has been edited by Fiero Vampire (edited 04-07-2016).]
Fiero Vampire
Report this Post04-07-2016 05:44 PM Click Here to See the Profile for Fiero VampireSend a Private Message to Fiero VampireEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero Vampire
Member since Nov 2013
Here I found the Google cached page for Fieroguru's thread DIY - How to drill 5 x 100 mm wheel bolt pattern for brake rotor upgrade - 5x100
carbon
Total ratings: 130
Report this Post04-07-2016 05:54 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats is weird... Cliff doesn't usually delete threads... for any reason really...
[This message has been edited by carbon (edited 04-07-2016).]
Report this Post04-07-2016 07:21 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, that is odd. I link to that thread in my 13" kit thread...
I have revised it to use this link:
https://web.archive.org/web...um2/HTML/120346.html
j bf1
Report this Post04-08-2016 12:00 AM Click Here to See the Profile for j bf1Send a Private Message to j bf1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks a lot guys!
DKcustoms
Report this Post04-08-2016 01:30 AM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Drilled my first 2 rotors ever about 2 months ago.
Took the stock Fiero rotor, laid it on top of the new one and taped them together after making sure everything was good.
Then I just used a marker to fill in the holes.
Separated the two, then started with a small drill bit and worked up to a 1/2" or 3/4, I forget now.
Milwaukee Titatnium drill bits had it feeling like I was drilling through plywood
[URL=https://www.zoro.com/milwaukee-drill-bit-set-titanium-14-pcs-48-89-0011/i/G4924771/?gdffi=047ada998cf641fa93e55ae8579df863&gdfms=F84781B2C0404AD395D0E3A7C9BD33DD&gclid=Cj0KEQjwipi4BRD7t6zGl6m75IgBEiQAn7CfFyncEk4j7aZc_IWc0Fe5CkVk36VhiYJSZ93qcsHPYHkaAto T8P8H]https://www.zoro.com/milwau...Z93qcsHPYHkaAtoT8P8H[/URL]
[This message has been edited by DKcustoms (edited 04-08-2016).]
carbon
Total ratings: 130
Report this Post04-08-2016 12:24 PM Click Here to See the Profile for carbonSend a Private Message to carbonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heh... excellent linksmanship there...
Milwaukee Drill Bit Set, Titanium, 14 pcs.
rogergarrison
Total ratings: 551
Report this Post04-08-2016 02:09 PM Click Here to See the Profile for rogergarrisonSend a Private Message to rogergarrisonEdit/Delete MessageReply w/QuoteDirect Link to This Post
My personal preference would be take them to a machine shop, have the original holes welded shut, then have them drill the new ones. Holes just a 1/32" out of place can cause vibrations you wont be able to get id of.
[This message has been edited by rogergarrison (edited 04-08-2016).]
Report this Post04-08-2016 06:30 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The concentric rings keep the rotor centered, the holes don't need a high level of precision.
For my kits, I took a rear wheel bearing, dial indicated it on my mill and bored each hole to accept a drill bushing and tacked them in place. I have done over 100 rotors will this tool.
