Listen to Buddycraig, you only need to take the door pad off to remove the door side hinge, but support the door before ever removing it, a helper is best. Not sure what side is easier to remove, door side or frame side as the both require trim removal and being a contortionist to get at some of the bolts. To me it is easier to just pull the door pins and remove the door then work on what ever hinge you want. Lots more room to work. But beware, these dam doors are heavy, a helper is a good idea to keep from damaging the door. also have someplace that you can just set the door down on, a padded saw horse or short stool, but if you do that and have any electrics in the door, Electric door locks, electric windows, and such, you will need to unplug those from inside the door or behind the kick pad inside the car. if you have a small table or stool cover it with foam like pillows or anything that will prevent scratching the doors paint and parts.
Each hinge has a hidden bolt in a place you need to be a contortionist to get at so beware of that. I hung my door from the rafters in my shop with some heavy duty rope but a helper is best, they can help to keep the door from twisting or damaging itself if you drop it.
Steve
[This message has been edited by 84fiero123 (edited 01-22-2016).]
