I've seen some really neat stuff on here with regards to suspension discussion, along with drawings,etc. Does anyone have an actual model/drawing of the rear knuckle that can be used for mounting points and measurements?
I have access to 3D scanner and CMM/Faro, just trying to see if someone out there already has a model, would make things easier.
I either need to machine the 88 knuckle for a larger bearing, or I'm going to pick up the factory mounting points and fab up a new one. I'm tired of breaking axles due to these tiny stub shafts.
I did see that. Later in the thread it looks like aaron88 has it modeled but I'm not sure what that is based on. I have used the larger Pontiac Transport parts in a pre-88, and would like to use the same axles in my 88 swapped car.
if you make something, I'd be interested in a set depending on cost and lead time.
------------------ "I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
oh.... this is what I was thinking as well. Maybe the C6 hub bearing redrilled for the right pattern and a custom axle made. Was thinking of sending a knuckle out for 3d scanning to
