  Front Turn/parking light wire colors
Front Turn/parking light wire colors by 87RedRum
Started on: 12-14-2015 03:46 AM
Replies: 13 (1074 views)
Last post by: 87RedRum on 12-18-2015 02:18 AM
87RedRum
Report this Post12-14-2015 03:46 AM Click Here to See the Profile for 87RedRumSend a Private Message to 87RedRumEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am looking to wire some LED DRL Fog/Turn signals in place of the front factory marker/parking/turn signals. Ive seen so many diagrams and other "confusing" pics of wiring diagrams. I just want a simple color code for the front lights. I.e. parking and turn ('87 GT):
Parking light wire color (when parking lights and headlights are turned on, these stay on) -
Turn signal wire color (driver and passenger color, these blink with indicator) -
Hot color (12v constant or ignition) -
ground color -
Thanks!
[This message has been edited by 87RedRum (edited 12-14-2015).]
Report this Post12-14-2015 09:01 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The diagrams look confusing because the wiring is confusing.
http://fierocave.shorturl.com/
Look under: Electrical/Lighting/LED marker light
[This message has been edited by Gall757 (edited 12-14-2015).]
87RedRum
Report this Post12-14-2015 11:11 AM Click Here to See the Profile for 87RedRumSend a Private Message to 87RedRumEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, but that's not what I am looking for, I don't want to know how LED's work and don't work on a Fiero, I just need to know the wire colors are what (hot, ground, turn etc) for the front parking/turn signal indicators....
Report this Post12-14-2015 12:46 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
BRN is Brown
BLK is Black
LT BLU is light blue
DK BLU is dark blue
87RedRum
Report this Post12-14-2015 04:14 PM Click Here to See the Profile for 87RedRumSend a Private Message to 87RedRumEdit/Delete MessageReply w/QuoteDirect Link to This Post
I figured it out while installing my COB LED switchback parking-fog lights/turn signals. I will post up pics later.
Left Turn is light blue
Right Turn is dark blue
Parking is brown
Ground is black
87RedRum
Report this Post12-14-2015 04:15 PM Click Here to See the Profile for 87RedRumSend a Private Message to 87RedRumEdit/Delete MessageReply w/QuoteDirect Link to This Post
87RedRum
Member since Sep 2015
BRN is Brown
BLK is Black
DK BLU is dark blue
Thanks!
Report this Post12-14-2015 04:19 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
See my Cave, Wire Reading to read detail of image above and others.
DRL/Fog/turn in same spot can/will confuse other drivers.
Many New cars turn off DRL on side w/ active turn signal for this reason. (Likely required by law in many counties.)
Fog/driving lights should be separate from turn lights.
Both can "hide" the turn lights by overpowering turn lights. Turn is ~27 watts but fog/driving are 50w or more. LED can do same thing.
Might look ok in a driveway but 30-100 yards away and other drivers likely have no clue you about to turn.
Wired and/or mounted wrong can make you a ticket magnet for any cop anywhere you drive to or tru.
[This message has been edited by theogre (edited 12-14-2015).]
87RedRum
Report this Post12-14-2015 05:09 PM Click Here to See the Profile for 87RedRumSend a Private Message to 87RedRumEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did install mine so that only the foglights are on, and when the turn signal is on (Left or Right) the foglights turn off on both sides. These are the exact way newer cars like Kia, Chrysler, Lexus etc (to name a few) do their switchbacks.
87RedRum
Report this Post12-14-2015 05:16 PM Click Here to See the Profile for 87RedRumSend a Private Message to 87RedRumEdit/Delete MessageReply w/QuoteDirect Link to This Post
87RedRum
Click on the link for my video on FB showing how the new COB LED Switchback fog-lights/turn signals I installed work. They came out GREAT!!! Highly recommended.
Fiero COB LED Switchbacks
1Packrat
Report this Post12-16-2015 07:33 AM Click Here to See the Profile for 1PackratSend a Private Message to 1PackratEdit/Delete MessageReply w/QuoteDirect Link to This Post
You Highly recommended them but:
Where did you get them
How did you wire them into the Fiero
curious minds want to know.....
Report this Post12-17-2015 04:19 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does Front marker blinks when parking lights are on AND off, on when park switch is on and turn signal is off, as shown on See my Cave, LED Marker Light
Should be but can't tell from your video.
If marker lights don't work correctly then you're not done.
LED for front park/turn is know problem and often require "load resistor(s)" to make marker to work.
read about resistors at See my Cave, LED poisoning
I don't have much for this problem in front because too many way to wire LEDs.
Is likely too bright claiming DRL and if cops stop you for Fog/Driving lights on w/o low beam HL can get you a ticket in most places. Some state is an equipment ticket and 0 point, others is moving violation w/ points.
Buy new HL bulbs. Odd bulbs could make you a bigger target for cops. See my Cave, Headlights
[This message has been edited by theogre (edited 12-17-2015).]
87RedRum
Report this Post12-18-2015 02:10 AM Click Here to See the Profile for 87RedRumSend a Private Message to 87RedRumEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, front markers blink when parking light are on AND off. They work exactly as the factory lights, just shine white when no turn signal is used, and amber when it is. They work as they should with no lights on, parking lights on, and headlights on...I have the LED flash can, so no hyper blink issues either.
And my headlights are low beam, they are composite headlights with projectors and HID's, so those are the low beams shown. the fog-lights (DRL's) are positioned correctly, as I was showing them at vehicle height with the camera. I don't know where you live, but I have HID's and LED fog lights on ALL of my vehicles, and have NEVER been pulled over for lighting....also the headlight bulbs match, just my camera on my phone at that angle picked up on the color funny to make one look blue and the other pink, both are 6000K HID headlights.
[This message has been edited by 87RedRum (edited 12-18-2015).]
87RedRum
Report this Post12-18-2015 02:11 AM Click Here to See the Profile for 87RedRumSend a Private Message to 87RedRumEdit/Delete MessageReply w/QuoteDirect Link to This Post
87RedRum
87RedRum
Report this Post12-18-2015 02:18 AM Click Here to See the Profile for 87RedRumSend a Private Message to 87RedRumEdit/Delete MessageReply w/QuoteDirect Link to This Post
87RedRum
Ordered them from EBay (They are made by YCL/Modify Street: COB LED Daytime Running Lights), they were only $22. See above on wiring. There are only 4 wires to these lights, hot (red), ground (black), left turn (yellow), & right turn (blue). I have the factory wire color codes mentioned above as to which color goes to what original harness color.
