  Auto to manual Wiring harness?
Auto to manual Wiring harness? by FieroCat
Started on: 11-24-2015 10:59 AM
Replies: 7 (844 views)
Last post by: Dr. Trey on 11-28-2015 09:38 AM
FieroCat
Report this Post11-24-2015 10:59 AM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys, I am rebuilding a spare 2.8 V6 engine for a school project. It had an auto tranny attached but I will likely be using my existing 4 speed manual with it when I swap it in. Is the auto wiring harness the same as the manual other than the wires that go into the auto tranny? Or will I have to re-use my existing 4spd harness?
My Fiero: 1986 Pontiac Fiero GT, V6, 4-speed manual
MulletproofMonk
Total ratings: 78
Report this Post11-24-2015 04:19 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
C500 has a pin you will need to move:
E2 is the starter on a manual transmission
A4 is the starter on an automatic transmission
So you will need to move C500 pin A4 to pin E2 if you are using an auto harness on a manual car.
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
dobey
Total ratings: 371
Report this Post11-24-2015 04:48 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would say just use the manual harness already in the car, and correctly pinned, and sell the auto harness.
Total ratings: 207
Report this Post11-24-2015 07:22 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't forget the back up light circuit......
FieroCat
Report this Post11-24-2015 08:04 PM Click Here to See the Profile for FieroCatSend a Private Message to FieroCatEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like it will indeed require some modification... I'll just use my manual one. Will likely post the auto harness up for sale in the mall soon. Thanks!
Total ratings: 328
Report this Post11-27-2015 06:08 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
As long as he makes the connection to the TCC, that should work fine.
dobey
Total ratings: 371
Report this Post11-27-2015 07:04 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is no TCC in a manual car.
Dr. Trey
Report this Post11-28-2015 09:38 AM Click Here to See the Profile for Dr. TreySend a Private Message to Dr. TreyEdit/Delete MessageReply w/QuoteDirect Link to This Post
My standard swaped 3.4 is using an auto harness with the prnd21 switch left in neutral position, column neutral safety switch left in neutral position, and extended speed sensor wires.
